Kernel: 6.15.9-1-vfio arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-vfio
root=UUID=748fc83f-8edc-436a-a837-2ebf04b7a602 rw rootflags=subvol=@
rd.driver.pre=vfio-pci loglevel=3 iommu=1 amd_iommu=on ibt=off
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
UEFI: American Megatrends v: 4021 date: 08/09/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
Speed (MHz): avg: 3734 min/max: 556/4854 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3734 2: 3734 3: 3734
4: 3734 5: 3734 6: 3734 7: 3734 8: 3734 9: 3734 10: 3734 11: 3734 12: 3734
13: 3734 14: 3734 15: 3734 16: 3734 bogomips: 121598
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK
driver: vfio-pci v: N/A alternate: nouveau,nvidia_drm,nvidia
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 04:00.0 chip-ID: 10de:1c82 class-ID: 0300
Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 575.64.05 alternate: nouveau,nvidia_drm
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-3 empty: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 09:00.0 chip-ID: 10de:2504 class-ID: 0300
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
Monitor-1: DP-3 model: Samsung U32J59x serial: <filter> built: 2024 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 575.64.05
device-ID: 10de:2504 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: vfio-pci alternate: snd_hda_intel pcie: speed: Unknown lanes: 63
link-max: gen: 3 speed: 8 GT/s bus-ID: 04:00.1 chip-ID: 10de:0fb9
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-5: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:6
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
API: ALSA v: k6.15.9-1-vfio status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: veth82a23f8 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: vetha10d76d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethca82ea5 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: virbr1 state: down mac: <filter>
Local Storage: total: 11.83 TiB used: 7.22 TiB (61.0%)
fw-rev: 2B2QEXM7 temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000VN004-3CP101
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
used: 571.78 GiB (61.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 415.2 MiB (1.3%)
System Temperatures: cpu: 50.0 C mobo: 49.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 1360 fan-3: 0 fan-4: 1076 fan-5: 3253
fan-6: 0 fan-7: 0
Memory: total: 32 GiB available: 31.25 GiB used: 9.53 GiB (30.5%)
Processes: 476 Power: uptime: 15h 32m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2194 libs: 599 tools: pacseek,pamac,paru,yay
pm: flatpak pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.1.1 alt: 14 Shell: Bash
v: 5.3.3 default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.4-1):
System install date: 2024-09-28
Last full system update: 2025-08-06
This is the first page opening Rani.
When opening preferences the drop-down list is blurred behind the back ground settings
After switching back to the welcome screen then the number of updates shows up.
Like I said minor issue using the latest garuda-rani not the git version
