RANI is slow and laggy
Hi. I recently installed Garuda linux. As far as I can see, it is a successful distribution. There are automation tools like Rani. However, my problem is exactly here. When I first installed the distribution, Rani was experiencing random freezes. This problem was solved with the update that came later, but now, at least on my computer, Rani is slow and laggy. I have no other problems other than this problem. They say on the forum that Rani works properly after the update. I have an old computer (amd phenom 2 955, amd rx 6500 xt, 14 gb ram) This problem may be specific to me. I am also adding my inxi file while Rani is open.
  Kernel: 6.14.8-1-clear arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-clear
    root=UUID=cefc1a5d-9161-4b57-b8ac-aa5ff824db4f rw rootflags=subvol=@
    vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200 quiet loglevel=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland vt: 1
  Type: Desktop Mobo: Gigabyte model: GA-890GPA-UD3H serial: <superuser required>
    uuid: <superuser required> BIOS: Award v: FC date: 05/28/2010
  Info: model: AMD Phenom II X4 955 bits: 64 type: MCP arch: K10 level: v1 built: 2009-13
    process: AMD 45nm family: 0x10 (16) model-id: 4 stepping: 3 microcode: 0x10000C8
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache: L1: 512 KiB
    desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3200 min/max: 800/3200 scaling: driver: acpi-cpufreq governor: performance
    cores: 1: 3200 2: 3200 3: 3200 4: 3200 bogomips: 25715
  Flags: ht lm nx pae sse sse2 sse3 sse4a svm
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 24 [Radeon RX 6400/6500 XT/6500M]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:743f class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
    gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: Acer G225HQV serial: <filter> built: 2011 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
    gbm: drv: zink surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.1-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 6500 XT (radeonsi navi24 LLVM 19.1.7 DRM 3.61
    6.14.8-1-clear) device-ID: 1002:743f memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.313 layers: 5 device: 0 type: discrete-gpu name: AMD Radeon RX 6500 XT
    (RADV NAVI24) driver: mesa radv v: 25.1.1-arch1.1 device-ID: 1002:743f surfaces: N/A device: 1
    type: cpu name: llvmpipe (LLVM 19.1.7 128 bits) driver: mesa llvmpipe v: 25.1.1-arch1.1 (LLVM
  Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: Gigabyte GA-880GMA-USB3
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  API: ALSA v: k6.14.8-1-clear status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: ce00 bus-ID: 05:00.0
  Device-2: Ralink RT2870 Wireless Adapter driver: rt2800usb type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 8-1:2 chip-ID: 148f:2870 class-ID: 0000 serial: <filter>
  IF: wlp4s0u1 state: up mac: <filter>
  Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.1 lmp-v: 10 status:
  Local Storage: total: 223.57 GiB used: 15.47 GiB (6.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 240G size: 223.57 GiB
    fw-rev: 0754 scheme: MBR
  ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 15.47 GiB (6.9%) fs: btrfs
    dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 15.47 GiB (6.9%) fs: btrfs
  ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 15.47 GiB (6.9%) fs: btrfs
  ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%) used: 15.47 GiB (6.9%) fs: btrfs
  ID-1: swap-1 type: zram size: 13.64 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lz4,deflate max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 46.2 C mobo: N/A gpu: amdgpu temp: 47.0 C mem: 48.0 C
  Memory: total: 16 GiB note: est. available: 13.64 GiB used: 3.48 GiB (25.5%)
  Processes: 268 Power: uptime: 55m states: freeze,mem,disk suspend: deep avail: s2idle
    wakeups: 2 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.44 GiB
  Packages: pm: pacman pkgs: 1356 libs: 394 tools: octopi,paru Compilers: clang: 19.1.7
    gcc: 15.1.1 Client: Unknown Client: garuda-rani inxi: 3.3.38
  System install date:     2025-05-21
  Last full system update: 2025-05-28
The developer is using every spare minute to solve the problems.
We ask for your patience. :slight_smile:
Until then, we recommend handling everything in the terminal as usual.
I understand, thank you.
