Greetings.
I get random occasional remote control requests while playing an online game (Monster Hunter World). The request is as follows:
“Remote control requested
An application requested access to:
*Input devices”
[EDIT: It turns out this request shows up whenever I touch the trackpad on my PS4 controller]
If possible, I’d like to prevent the request from showing up.
Kernel: 6.10.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b042db9a-ac81-4de7-8c5b-ef5f57decab3 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Mobo: ASUSTeK model: PRIME B550M-A v: Rev X.0x
UEFI: American Megatrends v: 3607 date: 03/22/2024
Device-1: ps-controller-battery-90:fb:a6:e5:49:e7 model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4198 high: 4200 min/max: 2200/5361 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4200
3: 4200 4: 4200 5: 4196 6: 4200 7: 4199 8: 4200 9: 4189 10: 4196 11: 4200
12: 4200 13: 4200 14: 4200 15: 4200 16: 4200 bogomips: 134404
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-2 empty: DP-1, DP-3, HDMI-A-1,
HDMI-A-2 bus-ID: 0b:00.0 chip-ID: 10de:2482 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-2 res: 2560x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2482
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FiiO K5 Pro driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 2972:0047
class-ID: fe01
API: ALSA v: k6.10.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: up speed: 100 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.4:6
rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 8.19 TiB used: 415.31 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital model: WD BLACK
SN750 SE NVMe 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 39.9 C
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
used: 415.31 GiB (44.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-1: swap-1 type: zram size: 15.53 GiB used: 188.2 MiB (1.2%)
System Temperatures: cpu: 46.5 C mobo: N/A
Memory: total: 16 GiB available: 15.53 GiB used: 4.46 GiB (28.7%)
Processes: 385 Power: uptime: 49m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1967 libs: 549 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-05-25
Last full system update: 2024-08-05
