Random hard freezes on Garuda Linux KDE (solved) [Toshiba Satellite C75D-B]
When I initially installed Garuda it worked wonderfully however I started getting random “hard” freezes where I couldn’t get to shell, control the mouse etc…everything appeared froze…after some testing the common denominator appeared to be watching video on youtube. One of the procedures I’d followed was to go into the hardware section and install the specific driver for my built in video on this machine (laptop). I decided to remove that driver and go back to the standard video (vesa?) and the problem went away. In retrospect I could have probably also tried SSH’ing into the pc but I noticed when I installed a bluetooth usb dongle even when pc was “froze” it beeped to indicate the system had recognized it. This suggested the system was fine…I was just unable to interact with it. Removing the driver fixed the issue and I though I’d share the solution in hopes of it helping someone else in a similar situation. garuda-inxi follows.
  Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=79745ca8-8cb4-4e47-afea-d5b9a6dff7c8 rw rootflags=subvol=@
    quiet rd.luks.uuid=03fde42e-0aa9-4f4a-b9a5-95ecdd3560fb loglevel=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
    wm: kwin_wayland with: krunner vt: 2 dm: SDDM Distro: Garuda
  Type: Laptop System: TOSHIBA product: Satellite C75D-B v: PSCLEU-032004
  Mobo: TOSHIBA model: Portable PC v: MP serial: <superuser required>
    part-nu: PSCLEU uuid: <superuser required> UEFI-[Legacy]: Insyde v: 1.30
    date: 08/14/2014
  ID-1: BAT0 charge: 44.7 Wh (100.0%) condition: 44.7/48.6 Wh (92.0%)
    volts: 10.8 min: 10.8 model: PA5109U-1BRS type: Li-ion serial: <filter>
    status: full
  Info: model: AMD A6-6310 APU with AMD Radeon R4 Graphics bits: 64 type: MCP
    arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
    model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 2196 min/max: 1000/1800 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 2196 2: 2196 3: 2196
    4: 2196 bogomips: 14372
  Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics]
    vendor: Toshiba driver: radeon v: kernel alternate: amdgpu arch: GCN-2
    code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 ports:
    active: eDP-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9851
  Device-2: Chicony TOSHIBA Web Camera - HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:3
    chip-ID: 04f2:b448 class-ID: 0e02
    alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: 0
  Monitor-1: eDP-1 res: 1600x900 size: N/A modes: N/A
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1 glx-v: 1.4
    direct-render: yes renderer: KABINI (radeonsi LLVM 18.1.8 DRM 2.50
    6.10.10-zen1-1-zen) device-ID: 1002:9851 memory: 1000 MiB unified: no
    display-ID: :0.0
  Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
    vendor: Toshiba driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    chip-ID: 1002:9840 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Toshiba
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
  API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
    driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 05:00.0 chip-ID: 168c:0032 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:7 chip-ID: 0bda:a725
  Report: btmgmt ID: hci0 rfk-id: 7 state: up address: <filter> bt-v: 5.1
  Local Storage: total: 931.51 GiB used: 14.94 GiB (1.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 1TB SSD
    tech: SSD serial: <filter> fw-rev: 0613 scheme: MBR
    used: 14.94 GiB (1.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-03fde42e-0aa9-4f4a-b9a5-95ecdd3560fb
  ID-1: swap-1 type: zram size: 14.6 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 55.1 C mobo: N/A gpu: radeon temp: 56.0 C
  Memory: total: 16 GiB note: est. available: 14.6 GiB used: 5.6 GiB (38.3%)
  Processes: 230 Power: uptime: 18h 40m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 5.83 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 1342 libs: 355 tools: octopi,paru Compilers:
    gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: yakuake
    inxi: 3.3.36
  System install date:     2024-09-15
  Last full system update: 2024-09-23 ↻
Hi there @FameWolf, and welcome to the Garuda forum. I see you have added “Solved” to your thread title. Please be kind enough to post the solution you found for others benefit.
The most common solution in cases like yours is to turn off “hardware acceleration” in your web browser.
Again, welcome to the Garuda community. :wave:
My solution was uninstalling the specific MT driver installed by the auto install under hardware and going back to the “default video” driver. I assume you are referring to media.hardware-video-decoding.enabled and media.hardware-video-decoding.force-enabled? I can set them to false and reinstall the driver to see if it also fixes the problem.
Give it a try if you feel like it. Otherwise, if you find your solution acceptable then no need to bother.
Your method appears to work as well and obviously is a cleaner solution. My concerns are whether I’ll run into the same issue with that driver when other apps like mpv, vlc etc try to use hardware decoding and also if not using hardware decoding what benefits does the ATI R4/R5 give me that I didn’t have with “video-linux”? Thanks for your time.
+oops+ I found the hardware accel checkbox you were referring to as opposed to the about:config parms. I’ve disabled it and reenabled the parms…so far no issue.
