Hello there,
I just installed the latest Garuda XFCE edition and I quite like it, specially for it's speed and responsiveness.
Nevertheless I get random freezes when using Zen Kernel.
This is quite annoying as data might be lost (my browser profile data especially, which I store in memory with the help of profile-sync-daemon) if I have to switch power off in order to reboot.
LTS works fine most of the time, although I had one freeze as well.
Could anyone give me a hint on how to debug this?
Here is some system information (inxi output):
inxi --full
System: Host: connzens-desktop Kernel: 5.4.74-1-lts x86_64 bits: 64 Desktop: Xfce 4.14.3 Distro: Garuda Linux
Machine: Type: Mini-pc System: Intel Client Systems product: NUC10i7FNH v: K61081-302 serial: <superuser/root required>
Mobo: Intel model: NUC10i7FNB v: K61360-302 serial: <superuser/root required> UEFI: Intel
v: FNCML357.0046.2020.0928.1457 date: 09/28/2020
CPU: Info: 6-Core model: Intel Core i7-10710U bits: 64 type: MT MCP L2 cache: 12.0 MiB
Speed: 802 MHz min/max: 400/1100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Graphics: Device-1: Intel driver: i915 v: kernel
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting resolution: 3840x2160~60Hz
Drives: Local Storage: total: 1.70 TiB used: 529.45 GiB (30.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 250GB size: 232.89 GiB
ID-2: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50 size: 465.76 GiB
ID-3: /dev/sdb type: USB vendor: Seagate model: ST1000LM 048-2E7172 size: 931.51 GiB
ID-4: /dev/sdc type: USB vendor: Sabrent model: SABRENT size: 111.79 GiB
ID-5: /dev/sdd type: USB vendor: Generic model: Flash Disk size: 3.75 GiB
Partition: ID-1: / size: 202.80 GiB used: 25.82 GiB (12.7%) fs: btrfs dev: /dev/nvme0n1p1
ID-2: /home size: 457.40 GiB used: 258.02 GiB (56.4%) fs: ext4 dev: /dev/sda1
ID-3: /var/log size: 202.80 GiB used: 25.82 GiB (12.7%) fs: btrfs dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 29.80 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
ID-2: swap-2 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-3: swap-3 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram1
ID-4: swap-4 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram2
ID-5: swap-5 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram3
ID-6: swap-6 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram4
ID-7: swap-7 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram5
ID-8: swap-8 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram6
ID-9: swap-9 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram7
ID-10: swap-10 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram8
ID-11: swap-11 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram9
ID-12: swap-12 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram10
ID-13: swap-13 type: zram size: 663.0 MiB used: 0 KiB (0.0%) dev: /dev/zram11
Help is greatly appreciated, as I'd really like to continue using Garuda Linux.
Best regards,
Constnatin
That's because I opted for
