Hello Good people, my device is just randomly logging me out of my session. So at first I thought it was because of something that I did, but then I reloaded my earliest snapshot but it still persists, what could be the problem?
I also reset my configs.
It restarted itself and displayed this!
Processing: 16457659595688687021001821225505.jpg...
Kernel: 5.15.25-1-lts x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c9eb3dd0-2491-4235-9bb3-c5a860d57d06 rw rootflags=subvol=@
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80G0 v: Lenovo G50-30
serial: Chassis: type: 10 v: Lenovo G50-30
serial:
Mobo: LENOVO model: Lancer 5A6 v: SDK0F82990WIN
serial: UEFI: LENOVO v: A7CN40WW date: 07/18/2014
ID-1: BAT0 charge: 9.1 Wh (98.9%) condition: 9.2/28.5 Wh (32.1%)
volts: 16.3 min: 14.4 model: Lenovo type: Unknown serial:
status: Charging
Info: model: Intel Pentium N3540 bits: 64 type: MCP arch: Silvermont
family: 6 model-id: 0x37 (55) stepping: 8 microcode: 0x838
Topology: cpus: 1x cores: 4 smt: cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2500 high: 2628 min/max: 500/2666 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2483 2: 2329 3: 2563
4: 2628 bogomips: 17333
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: spec_store_bypass status: Not affected
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Lenovo driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0f31
Device-2: Acer Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 1-4.1:4 chip-ID: 5986:055d class-ID: 0e02 serial:
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: eDP1 mapped: eDP-1 model: BOE Display built: 2015
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.4x7.5")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:0f04 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-lts running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b4 class-ID: 0280
IF: wlp2s0 state: up mac:
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
bus-ID: 1-4.3:6 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address:
Local Storage: total: 465.76 GiB used: 33.25 GiB (7.1%)
model: WD5000LPCX-24C6HT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial:
rev: 1A02 scheme: GPT
ID-1: / raw-size: 70.09 GiB size: 70.09 GiB (100.00%)
used: 33.22 GiB (47.4%) fs: btrfs dev: /dev/sda9 maj-min: 8:9
used: 30.1 MiB (11.8%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 70.09 GiB size: 70.09 GiB (100.00%)
ID-4: /var/log raw-size: 70.09 GiB size: 70.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 70.09 GiB size: 70.09 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.72 GiB used: 2.7 GiB (72.7%)
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 248 Uptime: 1h 48m wakeups: 1 Memory: 3.72 GiB
used: 3.24 GiB (87.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1341 pacman: 1322 lib: 348 flatpak: 0
snap: 19 Shell: Bash v: 5.1.16 running-in: kitty inxi: 3.3.13
