I’m having kind of a tough time trying to figure out how to install this program. Maybe someone could offer some advice?
The homepage of radium is here → Radium DAWg - For music
When I try to run the install script, I get a message about missing dependencies “tcl/tk”.
This is where I got stuck because I can’t figure out how to install these dependencies. ![]()
I found the package here Arch Linux - tcl 8.6.14-4 (x86_64)
I think that should work but I can’t figure out how to install that package!
Thank you for your time , :))
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=8daf4b71-dc9a-4bdb-b1c1-89acd05ad00e rw rootflags=subvol=@
Type: Convertible System: HP product: HP Envy x360 2-in-1 Laptop 14-es0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8BF7 v: 82.17 serial: <superuser required>
part-nu: 7H9Y4UA#ABA uuid: <superuser required> UEFI: Insyde v: F.03
date: 02/20/2023
ID-1: BAT0 charge: 37.9 Wh (100.0%) condition: 37.9/43.5 Wh (87.1%)
volts: 12.9 min: 11.6 model: 313-CD-3C-A PC03043XL type: Li-poly
serial: <filter> status: full cycles: 117
Device-1: hid-0018:04F3:41C3.0001-battery model: ELAN2514:00 04F3:41C3
serial: N/A charge: N/A status: N/A
Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x4121
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 635 high: 891 min/max: 400/4600:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 801 3: 400 4: 419
5: 593 6: 891 7: 400 8: 618 9: 842 10: 400 11: 585 12: 872 bogomips: 59904
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7a1 class-ID: 0300
Device-2: Luxvisions Innotech HP True Vision 5MP Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:3
chip-ID: 30c9:006a class-ID: fe01 serial: <filter>
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
device-ID: 8086:a7a1 memory: 7.3 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-U) driver: mesa intel v: 24.0.6-arch1.2
device-ID: 8086:a7a1 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.6-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Hewlett-Packard
chip-ID: 8086:51ca class-ID: 0401
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852ce v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:c852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:c85c
Report: btmgmt ID: hci0 rfk-id: 13 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 476.94 GiB used: 162.52 GiB (34.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPNQD-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS3 temp: 41.9 C scheme: GPT
used: 162.52 GiB (34.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.47 GiB used: 2.28 GiB (30.5%)
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 8 GiB note: est. available: 7.47 GiB used: 4.05 GiB (54.2%)
Processes: 295 Power: uptime: 3d 18h 3m states: freeze,mem,disk
suspend: s2idle wakeups: 12 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.98 GiB services: org_kde_powerdevil,
Packages: 1724 pm: pacman pkgs: 1666 libs: 430 tools: gnome-software,
octopi, paru, trizen pm: flatpak pkgs: 58 Compilers: gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-23
Last full system update: 2024-05-14
Is partially upgraded: Yes
