Radeon rx 580 wrong drivers maybe.
so I installed drivers according to Wiki and tried different mesa versions
https://wiki.archlinux.org/title/AMDGPU
when I run RPCS3 I get this
- RSX: Found Vulkan-compatible GPU: ‘AMD Radeon RX 480 Graphics (RADV POLARIS10)’ running on driver 24.0.3
E RSX: Your GPU does not support alpha-to-one for multisampling. Graphics may be inaccurate when MSAA is enabled.
E RSX: AMDGPU kernel driver on Linux and INTEL driver on some platforms cannot support passthrough DMA buffers.
alpha-to-one for multisampling and passthrough DMA buffers work fine in windows
lspci -k | grep -A 3 -E “(VGA|3D)”
07:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev c7)
Subsystem: Dell Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
some sites I was looking at saying Kernel modules should be Radeon
not sure how to change that.
any help would be greatly appreciated
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1d4a54c1-18da-4489-9dca-1711fda4fd49 rw rootflags=subvol=@
quiet resume=UUID=021293bc-c39f-4ed9-9c47-bc29b9877de7 loglevel=3
GRUB_CMDLINE_LINUX_DEFAULT=quiet ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: Gigabyte product: B450M DS3H v: N/A
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: F52
date: 01/05/2021
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3806 high: 4267 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3590 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 4263 8: 3800 9: 3800 10: 3800 11: 3800
12: 3573 13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 4267
20: 3800 21: 3771 22: 3800 23: 3589 24: 3696 bogomips: 182051
vendor: Dell driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 07:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 67.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3456x1944
display-ID: 0
Monitor-1: DP-3 pos: bottom-l res: 1536x864 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
(radeonsi polaris10 LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen)
device-ID: 1002:67df memory: 7.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 480 Graphics (RADV POLARIS10) driver: mesa radv
v: 24.0.4-arch1.1 device-ID: 1002:67df surfaces: xcb,xlib,wayland
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.61 TiB used: 127.11 GiB (7.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
fw-rev: S1111j0L temp: 36.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010CLA332
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3MA scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Silicon Power
model: SPCC Solid State Disk size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 61.3
scheme: MBR
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
used: 127.11 GiB (27.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-3: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-4: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 59.0 C mobo: 34.0 C gpu: amdgpu temp: 67.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 584
Memory: total: 16 GiB available: 15.56 GiB used: 4.41 GiB (28.3%)
Processes: 451 Power: uptime: 48m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1610 libs: 489 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-10
Last full system update: 2024-04-01
