Question about vmnet
Kernel: 6.12.28-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=3bc50495-a163-4556-a425-04d021d06cf2 rw rootflags=subvol=@
quiet resume=UUID=ad190a20-0362-44a1-9e8b-2a8b404739af loglevel=3 ibt=off
Type: Laptop System: Dell product: Precision 7530 v: N/A
Mobo: Dell model: 0425K7 v: A00 serial: <superuser required> part-nu: 0831
uuid: <superuser required> UEFI: Dell v: 1.41.0 date: 03/04/2025
ID-1: BAT0 charge: 91.2 Wh (100.0%) condition: 91.2/97.0 Wh (94.0%)
volts: 12.6 min: 11.4 model: SMP DELL 0WMRC7B type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8850H bits: 64 type: MT MCP arch: Coffee Lake
desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2701 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 2701 2: 2701 3: 2701 4: 2701 5: 2701 6: 2701
7: 2701 8: 2701 9: 2701 10: 2701 11: 2701 12: 2701 bogomips: 62431
ports: active: eDP-1 empty: DP-4, DP-5, DP-6, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Dell
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:1cbb class-ID: 0300
Device-3: Realtek Integrated Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:7 chip-ID: 0bda:5650
gpu: i915,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: C24X3F built: 2024 res:
mode: 1920x1080 hz: 100 scale: 100% (1) dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: LG Display 0x0540 built: 2017 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.5-arch1.1
GT2) device-ID: 8086:3e9b memory: 15.19 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.0.5-arch1.1
device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
name: Quadro P1000 driver: nvidia v: 570.144 device-ID: 10de:1cbb
surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits)
driver: mesa llvmpipe v: 25.0.5-arch1.1 (LLVM 19.1.7)
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
API: ALSA v: k6.12.28-1-lts status: kernel-api with: aoss
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 6f:00.0
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
Local Storage: total: 953.87 GiB used: 751.87 GiB (78.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS001TD9TNI-L2A0B size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11010C10 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 152.82 GiB size: 152.82 GiB (100.00%)
used: 103.13 GiB (67.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 17.3 MiB (0.9%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 341.8 GiB size: 341.8 GiB (100.00%)
used: 326.73 GiB (95.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 152.82 GiB size: 152.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 152.82 GiB size: 152.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.1 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 40.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 65.0 C mobo: N/A
Memory: total: 32 GiB available: 31.1 GiB used: 12.1 GiB (38.9%)
Processes: 383 Power: uptime: 6h 18m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: 1929 pm: pacman pkgs: 1921 libs: 546 tools: octopi,paru
pm: flatpak pkgs: 8 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
System install date:     2024-07-31
Last full system update: 2025-05-12
Why this?
Here vmware, It works good in my LAN:
Maybe this inxi does not show the current status ?
Start your vm, then the inxi or inside garuda-assistent button refresh.
before: (i personally use qemu/kvm)
active (default settings, no intern ip, dhcp assigned or what ever)
IF-ID-1: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: vnet2 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
OK, inside guest VM I run inxi -Fazy (Manjaro xfce):
  Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: VMware Virtual Machine
    type: network bridge driver: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.3
    chip-ID: 8086:7113 class-ID: 0680
  Device-2: Intel 82545EM Gigabit Ethernet vendor: VMware PRO/1000 MT Single
    Port driver: e1000 v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 8086:100f
  IF: ens32 state: up speed: 1000 Mbps duplex: full mac: <filter>
But in host:
IF: wlp111s0 state: down mac: <filter>
Maybe is filter blocking?
For network inxi -i or inxi --ip
You have “default” network settings ? (vmware + host)
Open konsole → ip link show = ?
My knowledge is that the “state” is unknown = regular
Why no speed status ? Can´t say why.
Tested with metal + vm (equal vmware or qemu/kvm)
Changing from nat/bridge/host-only and reverse → same result status speed i can see.
With inxi -i:
IF: wlp111s0 state: down mac: XXX
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A
vmware, and changing network to bridged.
Back to /dev/vmnet0:
funny ive read it but on my mobo is nothing like a virtual entry like you have. On my vm`s wired. i only have a issue when i start vmbox its asking for activate nat because is disabled but i dont see it in my inxi :face_with_raised_eyebrow:
I’m wired also… So, it’s a bug?
I mean not, we have different hardware/modules/settings.
That you see not the status “speed” for your vmnets. Is this important ?
No, important is … (my mind)
You have added VMware tools to the vm
yeah i didnt care about in my inxi if it all working like i wanted :wink:
Yes, VM is with open-vmware-tools, and, I have shared folder configured and running.
I think the same. Only garuda-inxi shows no information on vmware network, but all my VM’s are running all right without errors and with internet.
So, maybe there is some filter blocking information? I don’t know. I only ask because some forum show that vmware network information was weird.
By the way, is this solved?
Stupid question, but I’m using qeum/kvm with virt manager and I had to set my virtual networks to enable and start at boot.
Is there something similar with VMware?
i know what you mean had same issue with it too. i use oracle vmbox no problems at all :wink:
