Question about growing and deleting drive partitions
I have an HDD that I shrank down the whole partition (that is ntfs) and made the other half to btrfs, then copied all the files the the new half. Is it safe or a bad idea to just delete the ntfs section and grow the brtfs section the the entire drive? Supposedly it’s safe but I’m very hesitant. And another thing, at the start of the drive there’s a 15 MB partition called Microsoft reserved partition, this was never a bootable drive and never had any OS installed on it. I assume it’s fine to also delete that partition too? I’m not planning on using Windows anymore either and I have no idea why it’s there to begin with.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7b56fc96-0e19-473d-badd-73a065550c34 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.80 date: 12/15/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3697 high: 4316 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3597 2: 3599
3: 3614 4: 3589 5: 4316 6: 3589 7: 3700 8: 3598 9: 3596 10: 3633 11: 3600
12: 3937 bogomips: 88806
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1
empty: DP-1,DP-3,Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0032
Local Storage: total: 14.81 TiB used: 4.07 TiB (27.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000NM001G-2KJ103
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 731.71 GiB (39.3%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 731.71 GiB (39.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: zram size: 15.54 GiB used: 183.2 MiB (1.2%)
System Temperatures: cpu: 69.6 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1039
Memory: total: 16 GiB available: 15.54 GiB used: 4.84 GiB (31.1%)
Processes: 362 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1973 libs: 558 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2023-12-16
Last full system update: 2024-03-17
It’s perfectly safe to now delete the NTFS section and resize the BTRFS partition. One thing I noticed for storage drives is that EXT4 seems faster than BTRFS.
ah, too late now but thanks for letting me know.
Yea I learned the hard way cause I slowly converted my storage drives to BTRFS and moved my data only to realize after that I got a performance hit under BTRFS. It’s great for an OS, but just not storage.
