Jgmenu works, but I need to call it from dmenu or other start menu. It is probably not related to my hardware, as I changed my graphics card and cpu recently, but the issue persists. I tried reinstalling it and my graphics drivers, still nothing.
My inxi -Fxxxza output
yeah it's upstream issue. Qtile developers have made this change.
Solution: Do this changes in your qtile config file
I did it, and it still doesn't work
make sure you made correct changes and reboot system also remove import albattery
I am sure that I made correct changes, I downloaded the file and replaced contents of my config.py with this. I removed "import albattery" as well as another place where albattery was mentioned, a function which defines how it works, as it seems. I rebooted several times after every change, updated my system, and still nothing.
Also, another weird issue: even though I deleted "import albattery" it also persists, maybe, there is another config.py other then /etc/skel/.config/qtile/config.py
you have edited wrong config file. You have to edit config file in your home directory ~/.config/qtile/config.py
I assumed that the path used on this page is the needed one. The more you learn
