Updated using garuda-update yesterday, booting today caused an issue where qtile either isn't loading or is partially loading? On SDDM, I log in and a bar at the bottom appears. Login dialog box is still there, DE doesn't load or anything, but I'm able to make windows using M-r. My super + Q key doesn't close processes though.
Anyway, I checked that nvidia drivers are the usual ones, not changed. I replaced the ~/.xinitrc with the default from /etc/X11/xinit/xinitrc. When using ctrl + alt + F2 term, I tried running startx, which promptly shuts itself off with no errors. I have garuda-inxi output plus the qtile start outputs.
Restoring snapshots all the way to earlier this week resulted in same behaviors, almost like the snapshots didn't change anything. I don't really know how to interpret the Qtile start error, since I'm newer to linux. Would appreciate some assistance.
`garuda-inxi` output:
Kernel: 6.3.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=fec35a8a-ac27-428a-ab15-ff89bcf15665 rw [email protected]
loglevel=3 ibt=off
Desktop: Qtile v: 0.22.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 3.F1
date: 07/05/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2942 high: 3855 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2200
3: 2200 4: 3700 5: 3855 6: 2800 7: 3700 8: 2200 9: 2875 10: 3700 11: 3700
12: 2200 13: 3700 14: 2200 15: 2200 16: 3700 17: 3700 18: 3700 19: 2200
20: 2200 21: 2200 22: 2200 23: 3700 24: 2200 bogomips: 177599
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 25:00.0
chip-ID: 10de:1e89 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 4480x1440 s-dpi: 95 s-size: 1198x389mm (47.17x15.31")
s-diag: 1260mm (49.59")
Monitor-1: DP-0 pos: bottom-l res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Monitor-2: DP-4 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 16
bus-ID: 25:00.1 chip-ID: 10de:10f8 class-ID: 0403
bus-ID: 27:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech G733 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 046d:0ab5 class-ID: 0300
API: ALSA v: k6.3.3-zen1-1-zen status: kernel-api
Local Storage: total: 2.73 TiB used: 1.21 TiB (44.4%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
used: 24.97 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 37.1 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 352 Uptime: 23m wakeups: 0 Memory: available: 31.27 GiB
used: 2.15 GiB (6.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1321
libs: 459 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.27
System install date: 2023-04-25
Last full system update: 2023-05-23
`qtile start`
File "/usr/bin/qtile", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3.11/site-packages/libqtile/scripts/main.py", line 66, in main
options.func(options)
File "/usr/lib/python3.11/site-packages/libqtile/scripts/start.py", line 88, in start
q = make_qtile(options)
File "/usr/lib/python3.11/site-packages/libqtile/scripts/start.py", line 51, in make_qtile
kore = libqtile.backend.get_core(options.backend)
File "/usr/lib/python3.11/site-packages/libqtile/backend/__init__.py", line 15, in get_core
return importlib.import_module(f"libqtile.backend.{backend}.core").Core(*args)
File "/usr/lib/python3.11/site-packages/libqtile/backend/x11/core.py", line 104, in __init__
raise ExistingWMException(existing_wmname)
libqtile.backend.x11.core.ExistingWMException: LG3D
