qTile and Plank doesn't work well together
Hi people,
I just installed Garuda qTile. It is my first time trying a tiling window manager.
I am having some problems with Plank. It is becoming behind the applications making it impossible to use.
Also, I noticed a weird border around it. I tried edit .config/picom/picom-blur.conf and add plank to the shadow-exclude but it didn't work.
Does anyone had the same issue?
  Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=b8403481-0f10-494e-bf60-430c95843faf rw rootflags=subvol=@
  Desktop: Qtile v: 0.21.0 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
  Type: Desktop System: Gigabyte product: Z390 M GAMING v: N/A
  Mobo: Gigabyte model: Z390 M GAMING-CF v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F8
    date: 10/15/2019
  Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
  Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4966 high: 5005 min/max: 800/5000 scaling:
    driver: intel_pstate governor: performance cores: 1: 5003 2: 5003 3: 5001
    4: 5003 5: 4949 6: 4979 7: 4991 8: 4951 9: 4892 10: 4903 11: 4872
    12: 4983 13: 5000 14: 5005 15: 4971 16: 4951 bogomips: 115200
    vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
  Device-2: Xiongmai web camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-4.3.1:6 chip-ID: 23c5:1478 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.3 compositor: Picom v: git-c4107
    driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
  Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
    s-diag: 735mm (28.92")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) HDR WFHD
    serial: <filter> built: 2018 res: 2560x1080 hz: 60 dpi: 81 gamma: 1.2
    size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 2560x1080
    min: 640x480
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: Xiongmai web camera type: USB driver: snd-usb-audio,uvcvideo
  Device-4: Jieli MK-01 type: USB driver: snd-usb-audio bus-ID: 1-4.3.3:8
    chip-ID: 4c4a:4155 class-ID: 0102 serial: <filter>
  Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
    driver: r8188eu bus-ID: 1-11:3 chip-ID: 0bda:8179 class-ID: 0000
  IF: wlp0s20f0u11 state: down mac: <filter>
    bus-ID: 1-12:5 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
    port: 4020 bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
  Local Storage: total: 2.6 TiB used: 12.42 GiB (0.5%)
    model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
    rev: 102000WD temp: 48.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM014-1EJ164
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: DEMA
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DX001-1CM162
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 120GB
    type: SSD serial: <filter> rev: BB6Q scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
  ID-1: / raw-size: 111.15 GiB size: 111.15 GiB (100.00%)
    used: 11.98 GiB (10.8%) fs: btrfs dev: /dev/sdd3 maj-min: 8:51
    used: 449.4 MiB (87.9%) fs: vfat dev: /dev/sdd2 maj-min: 8:50
  ID-3: /home raw-size: 111.15 GiB size: 111.15 GiB (100.00%)
  ID-4: /var/log raw-size: 111.15 GiB size: 111.15 GiB (100.00%)
  ID-5: /var/tmp raw-size: 111.15 GiB size: 111.15 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.56 GiB used: 2 MiB (0.0%) priority: 100
  System Temperatures: cpu: 27.8 C pch: 55.0 C mobo: 16.8 C gpu: amdgpu
    temp: 48.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 818
  Processes: 365 Uptime: 22m wakeups: 2 Memory: 15.56 GiB
  used: 2.23 GiB (14.3%) Init: systemd v: 251 tool: systemctl Compilers:
  gcc: 12.1.0 Packages: pacman: 1379 lib: 331 Shell: fish v: 3.4.1
  default: Zsh v: 5.9 running-in: alacritty inxi: 3.3.16
 [1;34mGaruda (2.6.3-2): [0m
 [1;34m  System install date: [0m     2022-05-27
 [1;34m  Last full system update: [0m 2022-05-27
 [1;34m  Is partially upgraded:   [0m No
 [1;34m  Relevant software:       [0m NetworkManager
 [1;34m  Windows dual boot:       [0m Probably (Run as root to verify)
 [1;34m  Snapshots:               [0m Snapper
 [1;34m  Failed units:            [0m
Hi there, welcome to the forums!
Try to give a look at this one, still open but with a possible workaround at the end:
Hey @filo, thank for your reply.
I tried the workaround you suggested but I got the same result. The applications and run after running plank become in the top covering the plank icons. Also there is this weird translucent border.
The screenshot will explain better:
I see. I tried...
I've no experience with both qtile and plank...
The fact that the issue is open since 5 years is not a good sign in my opinion.
I wish you good luck, someone will know better hopefully!
I figure out how to make them work together using the script you suggested.
I added the script to my .local/bin directory and named plank-launcher:
$ cd ~/.local/bin
$ wget https://raw.githubusercontent.com/ntcarlson/dotfiles/tablet_test/i3/scripts/tablet_mode/launcher --output-document=plank-launcher
$ chmod _+x plank-launcher
Then I added this to my .config/qtile/config.py:
@hook.subscribe.startup_once
def plank_start():
    subprocess.Popen([home + "/.local/bin/plank-launcher", "start"])
@hook.subscribe.client_new
def plank_reload(_window):
    subprocess.Popen([home + "/.local/bin/plank-launcher", "show"])
This way, the plank will load on startup and every time a window is created, plank will be reloaded to become in front of all windows.
Also, to fix the weird translucent border, I added this to my .config/picom/picom-blur.conf:
blur-background-exclude = [
  "class_g = 'Plank'",
Now it is working.
