Hey there,
I just updated my system (updates included linux-zen and qt5-base) and now I can't run any desktop files outside of krunner or the application launcher.
All .desktop files lost their icons, the executable perm has been removed and I am greeted with this message when trying to open it (I also have the same problem with opening .json files for some reason):
Unknown error code 100
execvp: Exec format error
Please send a full bug report at https://bugs.kde.org.
In the terminal it says foo is marked as an executable but could not be run by the operating system.
Also whenever I rightclick on my desktop, the right click menu appears on my other screen...
Can u try pointing it to the bash file instead of just multimc maybe like /home/bin/multimc.sh something like that? or if its a jar java -jar /home/.......
Pamac is a good software to find information on packages and so on, but to update with it is rather scary. Now if it forced you to update, I would say remove it from your computer as soon as possible.
It kinda forced me, as I was just about to install a different package and was too lazy to switch to my terminal.
Apparently it's also broken when upgrading via the terminal
This is intentional.
There were times, where pacman completely broke my system, because some packages needed older packages, that pacman did not give them
