I've been curious about tiling window managers, and over the past month, have been trying to use hyprland as much as possible. Today, I tried to fixe a long-standing issue that I had, which was that qt apps were not respecting the sweetified or kvantum-dark theme, and so after some researching, installed qt5ct and followed the instructions on this Reddit Post. I added the lines
env = QT_AUTO_SCREEN_SCALE_FACTOR,0
env = QT_SCALE_FACTOR,1
env = QT_QPA_PLATFORM,wayland;xcb
env = QT_WAYLAND_DISABLE_WINDOWDECORATION,1
env = QT_QPA_PLATFORMTHEME,qt5ct
env = SDL_VIDEODRIVER,wayland
env = CLUTTER_BACKEND,wayland
to my hyprland.conf. These lines basically set the environment variables. Below here is my list of current environment variables active on hyprland.
SHLVL=2
PWD=/home/mab
GTK_IM_MODULE=fcitx
ALACRITTY_LOG=/tmp/Alacritty-229182.log
ALACRITTY_SOCKET=/run/user/1000/Alacritty-wayland-1-229182.sock
AMD_VULKAN_ICD=RADV
CSF_TObjDefaults=/usr/share/opencascade/resources/StdResource
BROWSER=vivaldi-stable
CLUTTER_BACKEND=wayland
CLUTTER_PAINT=disable-dynamic-max-render-time
CSF_DrawPluginDefaults=/usr/share/opencascade/resources/DrawResources
CSF_MDTVTexturesDirectory=/usr/share/opencascade/resources/Textures
CSF_PluginDefaults=/usr/share/opencascade/resources/StdResource
GTK_USE_PORTAL=0
CSF_ShadersDirectory=/usr/share/opencascade/resources/Shaders
CSF_XSMessage=/usr/share/opencascade/resources/XSMessage
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
COLORTERM=truecolor
DEBUGINFOD_URLS=https://debuginfod.archlinux.org
DRAWDEFAULT=/usr/share/opencascade/resources/DrawResources/DrawDefault
CSF_EXCEPTION_PROMPT=1
CSF_OCCTResourcePath=/usr/share/opencascade/resources
DRAWHOME=/usr/share/opencascade/resources/DrawResources
EDITOR=/usr/bin/vim
QT_QPA_PLATFORM=wayland;xcb
ALACRITTY_WINDOW_ID=94658643970736
SDL_IM_MODULE=fcitx
USER=mab
PATH=/home/mab/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/share/mycroft-core/bin:/usr/share/mycroft-core:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin:/home/mab/Applications/Mycroft/mycroft-core/bin
SDL_VIDEODRIVER=wayland
XDG_SESSION_DESKTOP=
CSF_XmlOcafResource=/usr/share/opencascade/resources/XmlOcafResource
XDG_CURRENT_DESKTOP=Hyprland
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
GTK2_RC_FILES=/home/mab/.gtkrc-2.0
QT_IM_MODULE=fcitx
SHELL=/bin/fish
WINDOWID=94658643970736
QT_QPA_PLATFORMTHEME=qt5ct
XDG_RUNTIME_DIR=/run/user/1000
MANPAGER=sh -c 'col -bx | bat -l man -p'
HG=/usr/bin/hg
XDG_SESSION_ID=15
MOZ_ENABLE_WAYLAND=1
LC_TIME=en_US.UTF-8
CSF_TObjMessage=/usr/share/opencascade/resources/TObj
MUTTER_DEBUG_ENABLE_ATOMIC_KMS=0
LC_PAPER=en_US.UTF-8
CASROOT=/usr
STARSHIP_SESSION_KEY=1[censored just in case]
CSF_LANGUAGE=us
STARSHIP_SHELL=fish
CSF_MIGRATION_TYPES=/usr/share/opencascade/resources/StdResource/MigrationSheet.txt
INPUT_METHOD=fcitx
HYPRLAND_CMD=Hyprland
CSF_IGESDefaults=/usr/share/opencascade/resources/XSTEPResource
XDG_SESSION_CLASS=user
LC_NUMERIC=en_US.UTF-8
QT_WAYLAND_DISABLE_WINDOWDECORATION=1
HOME=/home/mab
HYPRLAND_INSTANCE_SIGNATURE=[censored just in case]
FONTCONFIG_PATH=/etc/fonts
LC_MEASUREMENT=en_US.UTF-8
GDK_BACKEND=wayland
TERM=xterm-256color
CSF_StandardDefaults=/usr/share/opencascade/resources/StdResource
XDG_SEAT=seat0
WAYLAND_DISPLAY=wayland-1
LC_IDENTIFICATION=en_US.UTF-8
LC_NAME=en_US.UTF-8
MOTD_SHOWN=pam
_JAVA_AWT_WM_NONREPARENTING=1
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session13
XDG_DATA_DIRS=/home/mab/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
XDG_SESSION_TYPE=wayland
XDG_VTNR=1
LOGNAME=mab
MMGT_CLEAR=1
LC_ADDRESS=en_US.UTF-8
XDG_BACKEND=wayland
LC_TELEPHONE=en_US.UTF-8
XMODIFIERS=@im=fcitx
DISPLAY=:1
MAIL=thunderbird
CSF_SHMessage=/usr/share/opencascade/resources/SHMessage
QT_SCALE_FACTOR=1
XCURSOR_THEME=LyraG_Cursors
CSF_XCAFDefaults=/usr/share/opencascade/resources/StdResource
VISUAL=kate
PAM_KWALLET5_LOGIN=/run/user/1000/kwallet5.socket
CSF_STEPDefaults=/usr/share/opencascade/resources/XSTEPResource
XCURSOR_SIZE=24
DESKTOP_SESSION=hyprland
LC_MONETARY=en_US.UTF-8
QT_AUTO_SCREEN_SCALE_FACTOR=0
CSF_StandardLiteDefaults=/usr/share/opencascade/resources/StdResource
LANG=en_US.UTF-8
After adding the lines to hyprland.conf from earlier though, and logging out and back in to see the changes, all qt apps became too wide. A screenshot is attached below (I know it's not using hyprland and using Plasma instead, but couldn't get screenshots to work yet on hyprland, but the issue also persists on Plasma).
I have no idea why all the apps have a wider than normal aspect ratio. I tried removing the environment variables from hyprland.conf, and searching online, to no avail. If anyone knows anything about what could cause this issue, it would be well appreciated. This only affects qt apps it seems to me, other gtk based apps work just fine.
garuda-inxi:
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=2886e1d2-1f51-401c-9a54-77b069ecd400 rw rootflags=subvol=@
rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 splash
Desktop: Hyprland info: waybar dm: SDDM Distro: Garuda Linux
Type: Convertible System: LENOVO product: 20R5A000US v: ThinkPad L13 Yoga
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: LENOVO model: 20R5A000US v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: R15ET47W (1.28 ) date: 01/12/2021
ID-1: BAT0 charge: 9.1 Wh (20.1%) condition: 45.2/46.0 Wh (98.3%)
volts: 14.8 min: 15.4 model: SMP 5B10W13933 type: Li-poly serial: <filter>
status: discharging cycles: 216
Info: model: Intel Core i5-10210U socket: BGA1528 (U3E1) note: check
bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xC (12) microcode: 0xF6
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1275 high: 2100 min/max: 400/4200 base/boost: 1600/2100
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 1000 2: 1000 3: 1000 4: 2100 5: 2100 6: 1000
7: 1000 8: 1000 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:56a6
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: Hyprland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1
Monitor-1: eDP-1 model: LG Display 0x05ea built: 2018 res: 1920x1080
dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: GL data unavailable for root.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Local Storage: total: 238.47 GiB used: 197.25 GiB (82.7%)
model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 5M2QEXH7 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 165d 21h cycles: 5,246
read-units: 148,125,265 [75.8 TB] written-units: 70,934,036 [36.3 TB]
used: 197.25 GiB (82.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.35 GiB used: 550.9 MiB (7.3%)
System Temperatures: cpu: 17.0 C pch: 50.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 268 Uptime: 6h 18m wakeups: 20 Memory: available: 7.35 GiB
used: 3.14 GiB (42.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2405
pm: pacman pkgs: 2373 libs: 604 tools: gnome-software,octopi,paru
pm: flatpak pkgs: 32 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.27
System install date: 2023-05-07
Last full system update: 2023-07-03 ↻
