Garuda inxi:
❯ garuda-inxi
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a367fbf7-8c5c-44e7-975c-b5e9155cebdf rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH PLUS (MS-7A38) v: 7.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 9.00
date: 01/07/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2896 high: 3733 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2638 2: 2943
3: 2645 4: 3615 5: 3165 6: 3733 7: 2774 8: 2675 9: 2848 10: 2330 11: 2436
12: 2950 bogomips: 81587
STIBP: disabled, RSB filling
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DP-2,DP-3,HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 1f:00.0 chip-ID: 1002:67df class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,vesa alternate: fbdev gpu: amdgpu
Screen-1: 0 s-res: 3840x1800 s-dpi: 96 s-size: 1013x475mm (39.9x18.7")
s-diag: 1119mm (44")
Monitor-1: DisplayPort-1 mapped: DP-2 pos: bottom-c
model: Samsung C27R50x serial: <filter> built: 2018 res: 1920x1080 hz: 72
dpi: 82 gamma: 1.2 size: 598x336mm (23.5x13.2") diag: 686mm (27")
Monitor-2: DisplayPort-2 mapped: DP-3 pos: primary,bottom-l
model: Asus VG248 serial: <filter> built: 2018 res: 1920x1080 dpi: 92
gamma: 1.2 size: 531x299mm (20.9x11.8") diag: 609mm (24") ratio: 16:9
Monitor-3: HDMI-A-0 mapped: HDMI-A-1 pos: top-right model: Philips FTV
serial: <filter> built: 1990 res: 1280x720 dpi: 68 gamma: 1.2
size: 480x360mm (18.9x14.2") diag: 734mm (28.9") ratio: 16:9 modes:
max: 1024x768 min: 640x480
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.44.0
5.16.10-zen1-1-zen LLVM 13.0.1)
v: 4.6 Mesa 21.3.6 direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 1f:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 0c76:161e
Device-4: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:3 chip-ID: 0c76:161f
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.42 TiB used: 741.48 GiB (21.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.7
temp: 30.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
type: SSD serial: <filter> rev: 023 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A750
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 359.75 GiB size: 359.75 GiB (100.00%)
used: 184.18 GiB (51.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /home raw-size: 359.75 GiB size: 359.75 GiB (100.00%)
ID-3: /var/log raw-size: 359.75 GiB size: 359.75 GiB (100.00%)
ID-4: /var/tmp raw-size: 359.75 GiB size: 359.75 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.64 GiB used: 1.82 GiB (11.6%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 736
Processes: 392 Uptime: 29m wakeups: 0 Memory: 15.64 GiB
used: 3.86 GiB (24.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: apt: 0 pacman: 1842 lib: 495
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2021-10-24
Last full system update: 2022-02-23
Failed units: bluetooth-autoconnect.service mozillavpn.service
I am trying to build the mozilla-vpn-client from source using qt6, since building it with qt5 or using the executable from AUR since I just get a segfault.
In the process of building a mozilla provided command runs the qsb executable, which isn't present on my system although I ran sudo pacman -S qt6-base qt6-tools qt6-networkauth qt6-charts qt6-websockets qt6-shadertools.
From my point of view the qsb executable is in the qt6-shadertools package, since konsole tries to install that package when qsb isn't found.
I have searched a lot but I cannot find an answer to this problem.
