hello. Now I’ll remove garuda and install manjaro, if you don’t help with qbittorrent. Why is its top menu not the same as in Windows? There are no buttons to create a torrent, no button to turn off the computer after downloading. In manajaro the interface is normal, as it should be, in garuda…How to make a normal interface?
╰─λ garuda-inxi
Kernel: 6.6.16-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=2e45d363-1ea4-4b68-969e-814870346fc5 rw rootflags=subvol=@
quiet apparmor=1 security=apparmor udev.log_priority=3 iommu=pt
rcu_nocbs=0-3 quiet resume=UUID=6eed4e36-c250-4b1d-9966-84cfd3252615
loglevel=3 clearcpuid=514 quiet apparmor=1 security=apparmor
udev.log_priority=3 iommu=pt rcu_nocbs=0-3 ibt=off
v: 5.115.0 wm: kwin_x11 tools: avail: budgie-screensaver vt: 2 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
Megatrends LLC. v: 2.H0 date: 07/27/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2561 high: 4200 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3457 2: 2200
3: 2200 4: 3607 5: 2200 6: 2057 7: 2200 8: 2200 9: 2200 10: 4200 11: 2200
12: 2019 bogomips: 86430
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ASUSTeK
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-2
empty: DP-1, DP-2, HDMI-A-1, Unknown-2 bus-ID: 26:00.0 chip-ID: 10de:1f47
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-A-2 mapped: HDMI-1 note: disabled model: Asus ML229
serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 103 gamma: 1.2
size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:1f47
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM 16.0.6)
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 26:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.6.16-1-lts status: kernel-api with: aoss
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.47 TiB used: 470.64 GiB (31.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN750 SE 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 39.9 C scheme: GPT
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 58.59 GiB size: 58.59 GiB (100.00%) used: 15.5 GiB (26.5%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-3: /home raw-size: 390.57 GiB size: 390.57 GiB (100.00%)
used: 370.84 GiB (94.9%) fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:9
ID-4: /var/log raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
used: 15.5 GiB (26.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
ID-5: /var/tmp raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 15.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.4 C mobo: N/A gpu: nvidia temp: 48 C
Memory: total: 16 GiB available: 15.54 GiB used: 3.67 GiB (23.6%)
Processes: 383 Power: uptime: 1h 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: 1872 pm: pacman pkgs: 1864 libs: 560 tools: octopi,pamac,paru
pm: flatpak pkgs: 8 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-02
Last full system update: 2024-02-15 ↻
Failed units: snapd.failure.service snapd.service snapd.socket
