Hello everyone!! I have been searching for how pywal handles dual monitors and haven’t been able to find anything. I take that back. I found a function that will do what I need to do and I put that in my .zshrc. Can you use functions in polybar modules? Currently pywal puts the same wallpaper on each monitor and my resolution is 3840x1080. If anyone can point me in the right direction that would be great.
Rich
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6175aced-ff46-4d8b-8a4c-54245f06370a rw rootflags=subvol=@
Desktop: bspwm v: 0.9.10 with: krunner,polybar
tools: xscreensaver,xscreensaver-systemd avail: physlock,xfce4-screensaver
vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0
UEFI: American Megatrends v: 1.B0 date: 08/10/2020
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2345 high: 4939 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4935 2: 800 3: 800
4: 800 5: 800 6: 4889 7: 800 8: 4939 bogomips: 57600
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: Micro-Star MSI
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2187
compositor: Picom v: git-89c2c driver: X: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-2 note: disabled pos: right model: BenQ GW2780
serial: <filter> built: 2023 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,left
model: Asus VG278HE serial: <filter> built: 2015 res: 1920x1080 hz: 60
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB
API: Vulkan v: 1.3.276 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 545.29.06 device-ID: 10de:2187
surfaces: xcb,xlib
Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
bus-ID: 03:00.0 chip-ID: 10ec:8161 class-ID: 0200
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0b05:190e
Local Storage: total: 4.55 TiB used: 376.19 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: WDS200T3X0C-00SJG0 size: 1.82 TiB block-size: physical: 512 B
fw-rev: 102430WD temp: 47.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 163.9 GiB (8.8%)
used: 724 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 163.9 GiB (8.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.73 GiB used: 3.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 34.0 C pch: 49.0 C mobo: N/A gpu: nvidia
temp: 47 C
Memory: total: 64 GiB note: est. available: 62.73 GiB used: 6.42 GiB (10.2%)
Processes: 377 Power: uptime: 5d 1h 45m states: freeze,mem,disk
reboot, suspend, test_resume image: 25.05 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 2016 libs: 463 tools: octopi,paru Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: alacritty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-28
Last full system update: 2024-02-23 ↻
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: bspwm v: 0.9.10 with: polybar
tools: xscreensaver,xscreensaver-systemd avail: i3lock, physlock,
xfce4-screensaver vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4900:5000 scaling:
5: 801 6: 800 7: 800 8: 800 bogomips: 57600
surfaces: xcb,xlib
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 0b05:190e
Local Storage: total: 4.55 TiB used: 362.19 GiB (7.8%)
fw-rev: 102430WD temp: 44.9 C scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 98.63 GiB (5.3%)
used: 98.63 GiB (5.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.0 C pch: 47.0 C mobo: N/A gpu: nvidia
temp: 41 C
Memory: total: 64 GiB note: est. available: 62.73 GiB used: 4.86 GiB (7.7%)
Processes: 360 Power: uptime: 1d 5h 30m states: freeze,mem,disk
Packages: pm: pacman pkgs: 2036 libs: 463 tools: octopi,paru Compilers:
Garuda (2.6.23-1):
Last full system update: 2024-02-25 ↻
