I need to have both of PyCharm apps - Community and Proffesional but I can't install them togheter. When PyCharm CE is installed already and I'm trying to install Pycharm Pro Software Manager require to remove PyCharm CE.
I'm not familiar with linux console, especially in ArchLinux. Until I've discovered Garuda I've been using Ubuntu/Mint.
Distro is Garuda KDE Dragonized.
I'm using it for few days at the time.
Hi there, welcome!
Since you have a paid professional version, maybe you can ask support to the vendor?
If it is only a matter of licenses maybe you can try to use two different users.
No other ideas...
I think ( but I'm not sure ) it's OS dependent "feature" not application.
On other distros ( Ubuntu, Mint ) it works well and I was able to install both of them.
It is the way they are packaged by the maintainer(s).
That being said, if you don’t like my recommendation above of using flatpak for one of them, you could also install one of them manually into you home directory. I think the flatpak solution is easier in this case though.
Alternatively, you could create your own PKGBUILDs which don’t conflict.
