I always have to switch the audio device from analog output
to analog output + mono input
to get the sound work even if it was analog output + mono input
, plus its a 5.1 headset i cant get it working.
am using pulseaudio and alsa
Kernel: 6.6.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7758260e-7fbd-481e-9819-5335b028eb3f rw rootflags=subvol=@
mem_sleep_default=s2idle ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: HP Z220 CMT Workstation
v: N/A serial: <superuser required> Chassis: type: 6
Mobo: Hewlett-Packard model: 1790 serial: <superuser required>
UEFI: Hewlett-Packard v: K51 v01.61 date: 05/16/2013
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3564 high: 3900 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3900 3: 3900
4: 3900 5: 3900 6: 3112 7: 3900 8: 2007 bogomips: 54279
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ZOTAC driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: HDMI-A-1 empty: DVI-D-1,VGA-1
bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
Screen-1: 0 s-res: 1920x1200 s-dpi: 93 s-size: 524x321mm (20.63x12.64")
s-diag: 615mm (24.19")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled
model: Lenovo LEN LT2452pwC serial: <filter> built: 2014 res: 1920x1200
hz: 60 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 640x480
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 750 Ti driver: nvidia v: 545.29.06 device-ID: 10de:1380
surfaces: xcb,xlib
vendor: Hewlett-Packard 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ZOTAC
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-3: C-Media USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0d8c:0012 class-ID: 0300
API: ALSA v: k6.6.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.02 TiB used: 851.41 GiB (81.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 120G
tech: SSD serial: <filter> fw-rev: 979 scheme: GPT
model: WD10EARS-00Y5B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 24.53 GiB (22.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.62 GiB used: 590.8 MiB (5.0%)
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 33%
Processes: 337 Uptime: 1h 53m wakeups: 0 Memory: total: 12 GiB
available: 11.63 GiB used: 6.6 GiB (56.8%) Init: systemd v: 255
pm: pacman pkgs: 1853 libs: 531 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date: 2024-01-07
Last full system update: 2024-01-08 ↻
