After last update, who changed pulseaudio-alsa, Pulse Effects stops working. I've uninstalled and now I can't compile it from AUR, it says that need to remove pulseaudio-equalizer and it needs to uninstall pulseaudio-support. My hardware can't recognize Pipewire on Garuda Dr460nized (on Manjaro Gnome pipewire works fine). How I should proceed?
For PulseAudio use pulseeffects-legacy, current version only works with pipewire
You could also try installing
sudo pacman -S pipewire-support
@binarydepth, I use legacy version, it was exactly that one which stopped working. I know that the most recent version uses only Pipewire
@librewish , I don't know why, but pipewire doesn't work correctly wiht my laptop. It's a Dell Inspiron 3421. I've already tried to make it works with Garuda Assistant. At this moment I am using just Alsa, with Pipewire-dummy and Pulseeffects (regular version, not legacy), but the app doesn't load at all
Pulseeffects does crash on me with a SIGKILL signal. I just needed noise reduction so I am using NoieTorch.
With me simply doesn't load at all - just like Pulse with Pipewire when it had upgraded or now, with Pipewire-dummy. I think it may have something of a conflict with Alsa, but it's just a hunch
