seems like it might be a packaging issue based on this? Application Indicator menu grayed out (#20) · Issues · Jean-Philippe Orsini / psensor · GitLab
System: Kernel: 5.13.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ef15347e-a4da-4628-afc3-2bff20cbb710 rw [email protected] quiet splash
resume=UUID=e7745511-30a0-4b3d-93c1-4bc3daa8b2b8 loglevel=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: X470 Taichi serial: <filter> UEFI: American Megatrends
v: P3.50 date: 07/18/2019
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3 serial: <filter>
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86394
Speed: 4025 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4025 2: 4020
3: 4019 4: 4023 5: 4025 6: 4024 7: 4027 8: 4015 9: 4024 10: 4021 11: 4023 12: 4024
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Gigabyte driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 0e:00.0 chip-ID: 10de:1b80 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 3840x3240 s-dpi: 80 s-size: 1219x1029mm (48.0x40.5")
s-diag: 1595mm (62.8")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 52 size: 1872x1053mm (73.7x41.5")
diag: 2148mm (84.6")
Monitor-2: DP-0 res: 2560x1080 dpi: 81 size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0e:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-zen1-1-zen running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
port: e000 bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel port: d000
bus-ID: 0a:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:4
chip-ID: 8087:0aa7 class-ID: e001
Drives: Local Storage: total: 2.27 TiB used: 487.21 GiB (20.9%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 2B2QEXE7 temp: 49.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
type: SSD serial: <filter> rev: 3B7QCXE7 temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164 size: 1.82 TiB
serial: <filter> rev: CC41 scheme: GPT
Partition: ID-1: / raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 42.61 GiB (19.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 42.61 GiB (19.8%)
ID-4: /var/log raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 42.61 GiB (19.8%)
ID-5: /var/tmp raw-size: 215.45 GiB size: 215.45 GiB (100.00%) used: 42.61 GiB (19.8%)
ID-1: swap-1 type: partition size: 17.18 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 15.55 GiB used: 34 MiB (0.2%) priority: 100
Sensors: System Temperatures: cpu: 53.2 C mobo: 39.0 C gpu: nvidia temp: 51 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1304 fan-3: 1304 fan-4: 1492 fan-5: 1231 gpu: nvidia
fan: 24%
Power: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.28
Info: Processes: 478 Uptime: 1h 21m wakeups: 2 Memory: 15.55 GiB used: 9.79 GiB (62.9%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1973 lib: 513 flatpak: 0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06
