PS4 Dualshock unable to connect via bluetooth
Hello i did a brand new fresh install of garuda gnome edition 2 days ago
and my PS4 Dualshock controller will not connect via bluetooth, it only works with the usb cable.
(it was working in manjaro with bluetooth)
here is the output from the garuda assistant
i hope someone can help me fix this, as i dont want to go back to manjaro :frowning:
May 09 21:43:21 home-ms7b17 kernel: x86/cpu: SGX disabled by BIOS.
May 09 21:43:23 home-ms7b17 systemd-tmpfiles[735]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
May 09 21:43:23 home-ms7b17 bluetoothd[746]: src/plugin.c:plugin_init() Failed to init vcp plugin
May 09 21:43:23 home-ms7b17 bluetoothd[746]: src/plugin.c:plugin_init() Failed to init mcp plugin
May 09 21:43:23 home-ms7b17 bluetoothd[746]: src/plugin.c:plugin_init() Failed to init bap plugin
May 09 21:43:24 home-ms7b17 kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
May 09 21:43:24 home-ms7b17 kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
May 09 21:43:24 home-ms7b17 kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
May 09 21:43:31 home-ms7b17 gdm-password][2926]: gkr-pam: unable to locate daemon control file
May 09 21:43:32 home-ms7b17 systemd[2946]: Failed to start Application launched by gnome-session-binary.
May 09 21:43:34 home-ms7b17 systemd[2946]: Failed to start Application launched by gnome-session-binary.
May 09 21:43:58 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 09 21:43:58 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 09 21:44:04 home-ms7b17 kernel: Bluetooth: hci0: Opcode 0x 401 failed: -16
May 09 21:44:04 home-ms7b17 bluetoothd[746]: src/device.c:search_cb() 70:20:84:50:6B:9F: error updating services: Host is down (112)
May 09 21:44:18 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 09 21:44:18 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 09 21:44:28 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 09 21:44:28 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 09 21:45:00 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 09 21:45:00 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 09 21:45:08 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 09 21:45:08 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 10 00:18:39 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 10 00:18:39 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
May 10 00:18:46 home-ms7b17 bluetoothd[746]: profiles/input/server.c:connect_event_cb() Refusing input device connect: No such file or directory (2)
May 10 00:18:46 home-ms7b17 bluetoothd[746]: profiles/input/server.c:confirm_event_cb() Refusing connection from 70:20:84:50:6B:9F: unknown device
  Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=fb4f8752-5778-428b-984d-80e7a1caddca rw [email protected]
    loglevel=3 ibt=off
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: Micro-Star model: MPG Z390 GAMING EDGE AC (MS-7B17)
    v: 2.0 serial: <superuser required> UEFI: American Megatrends v: A.70
    date: 01/02/2020
  Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4344 high: 4807 min/max: 800/5000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4802 2: 4788 3: 3600
    4: 4807 5: 3600 6: 3600 7: 4799 8: 3600 9: 4800 10: 4766 11: 4763 12: 4800
    13: 4800 14: 4784 15: 3600 16: 3600 bogomips: 115200
  Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f06
    compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84")
  Monitor-1: DP-0 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x12.99")
    diag: 865mm (34.07") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2060
    SUPER/PCIe/SSE2 direct-render: Yes
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-3: EVGA NU Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 3842:3100
    class-ID: fe01
  API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api with: aoss
  Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
  Local Storage: total: 6.8 TiB used: 741.56 GiB (10.6%)
    model: WDS100T3XHC-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 102000WD temp: 52.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Zotac model: ZTSSD-A5P-480G-PE
    tech: SSD serial: <filter> fw-rev: 01.6 scheme: GPT
    model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
    fw-rev: 1A01 scheme: GPT
    used: 741.56 GiB (79.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 62.74 GiB used: 512 KiB (0.0%) priority: 100
  System Temperatures: cpu: 68.0 C pch: 70.0 C mobo: N/A gpu: nvidia
    temp: 54 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
  Processes: 393 Uptime: 2h 39m wakeups: 1 Memory: available: 62.74 GiB
  used: 5.74 GiB (9.2%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1402
  libs: 456 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.27
  System install date:     2023-05-09
  Last full system update: 2023-05-10 ↻
Some additional info
 ╰─λ bluetoothctl
Agent registered
[CHG] Device 70:20:84:50:6B:9F Connected: yes
[CHG] Device 70:20:84:50:6B:9F Connected: no
[DEL] Device 70:20:84:50:6B:9F Wireless Controller
[NEW] Device 70:20:84:50:6B:9F Wireless Controller
[CHG] Device 70:20:84:50:6B:9F Bonded: yes
[CHG] Controller AC:67:5D:A0:54:96 Discoverable: no
[CHG] Controller AC:67:5D:A0:54:96 Discovering: no
[CHG] Device 70:20:84:50:6B:9F Paired: yes
[bluetooth]#
Maybe you could try this package?
https://wiki.archlinux.org/title/Gamepad#Controller_not_recognized_when_using_Bluetooth
