Hello. I am having issues with protontricks. I use Garuda since over a year now and never used protontricks. At least I cannot remember. Now I need it to run a game and I have issues.
If I type ‘protontricks’ in my terminal I get the following error-message:
exec: Failed to execute process '/home/frankblack/.local/bin/protontricks': The file specified the interpreter '/home/frankblack/.local/share/pipx/venvs/protontricks/bin/python', which is not an executable command.
When I look into /home/frankblack/.local/share/pipx/venvs/protontricks/bin/ there are several symbolic (?) links.
- python → Points to python3.12 in the same folder
- python3.12 → Points to /usr/bin/python3.12
When I look into /usr/bin/ there is no python3.12, just python 3.13
I cannot remember ever fiddling with this.
Can someone please help me get protontricks up and running correctly?
My garuda-inxi:
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=05fecfb8-789d-4629-95f8-6324a5fdb33b rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.1 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: SchenkerGmbH product: XMG NEO 17(E20, RTX 20xx)
v: Standard serial: <superuser required>
Mobo: SchenkerGmbH model: GM7MxxS E20 v: Standard
serial: <superuser required> part-nu: XNE17E20 uuid: <superuser required>
UEFI: American Megatrends v: N.1.03 date: 06/30/2020
ID-1: BAT0 charge: 59.8 Wh (96.0%) condition: 62.3/62.3 Wh (100.0%)
volts: 15.9 min: 15.2 model: standard type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 scaling: driver: intel_pstate
bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: AIstone Global
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: AIstone Global driver: nvidia v: 570.86.16
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DP-1, DP-2, HDMI-A-1, eDP-2
bus-ID: 01:00.0 chip-ID: 10de:1e91 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:4 chip-ID: 04f2:b68b
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0884 built: 2019 res:
mode: 1920x1080 hz: 240 scale: 100% (1) dpi: 128 gamma: 1.2
size: 380x210mm (14.96x8.27") diag: 438mm (17.3") ratio: 16:9
modes: 1920x1080
drv: nvidia surfaceless: drv: nvidia x11: drv: swrast inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 19.1.7 256 bits)
device-ID: ffffffff:ffffffff memory: 61.16 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 Super driver: N/A device-ID: 10de:1e91 surfaces: xcb,xlib
device: 1 type: integrated-gpu name: Intel UHD Graphics (CML GT2)
driver: N/A device-ID: 8086:9bc4 surfaces: xcb,xlib device: 2 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: AIstone Global
Device-2: NVIDIA TU104 HD Audio vendor: AIstone Global
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
vendor: AIstone Global driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 2.73 TiB used: 719.45 GiB (25.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: FireCuda 510 SSD
ZP1000GM30001 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: STES1024
temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Seagate model: FireCuda 510 SSD
ZP2000GM30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
temp: 44.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 2.73 TiB (150.01%) used: 719.45 GiB (25.7%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.82 TiB size: 2.73 TiB (150.01%)
used: 719.45 GiB (25.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 1.82 TiB size: 2.73 TiB (150.01%)
ID-5: /var/tmp raw-size: 1.82 TiB size: 2.73 TiB (150.01%)
ID-1: swap-1 type: zram size: 62.62 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 73.0 C pch: 65.0 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.62 GiB used: 9.16 GiB (14.6%)
Processes: 414 Power: uptime: 5h 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
Packages: 2695 pm: pacman pkgs: 2681 libs: 625 tools: gnome-software,
octopi, pamac, paru pm: appimage pkgs: 0 pm: flatpak pkgs: 14 Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
Garuda (2.6.26-1.1):
System install date: 2023-10-29
Last full system update: 2025-02-24
