Hello,
I’m attempting to solve an issue with Proton Pass on Garuda. Frankly I’m not sure if it’s an application issue or OS one. I’ll reach out to Proton if there’s nothing I’m missing on the OS side.
When running Proton Pass desktop application you can click on field and it copies the content to the clipboard. The plugin on Brave works fine, but not so much on the desktop application.
I’ve confirmed checking the clipboard isn’t receiving the data by checking the history and also confirmed there is no auto clear of the clipboard currently turned on in the desktop application.
Any guidance would be appreciated.
Kernel: 6.12.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1e57882b-3332-48c9-830b-905e17336563 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: G22CH v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: ASUSTeK (Licensed by AMI LLC.) v: G22CH.411
date: 08/07/2024
Info: model: 13th Gen Intel Core i7-13700F bits: 64 type: MST AMCP
microcode: 0x12B
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:4100 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 101376
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: ASUSTeK driver: nvidia
v: 565.77 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,DP-3,HDMI-A-1 empty: DP-2 bus-ID: 01:00.0
chip-ID: 10de:2786 class-ID: 0300
gpu: nvidia,nvidia-nvswitch d-rect: 7680x1440 display-ID: 0
Monitor-1: DP-1 pos: right model: ViewSonic VX2776-4K-mhd serial: <filter>
built: 2020 res: mode: 2560x1440 hz: 60 scale: 150% (1.5) to: 1707x960
dpi: 160 gamma: 1.2 size: 608x355mm (23.94x13.98") diag: 704mm (27.7")
ratio: 15:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-3 pos: center model: AOC Q27G3XMN serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 165 scale: 150% (1.5) to: 1707x960
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-3: HDMI-A-1 pos: primary,left model: ViewSonic VX2776-4K-mhd
serial: <filter> built: 2020 res: mode: 2560x1440 hz: 60 scale: 150% (1.5)
to: 1707x960 dpi: 160 gamma: 1.2 size: 608x355mm (23.94x13.98")
diag: 704mm (27.7") ratio: 15:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4070 driver: N/A device-ID: 10de:2786
19.1.6 256 bits) driver: N/A device-ID: 10005:0000
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
Device-3: Corsair HS80 RGB USB Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-4.3.3:11 chip-ID: 1b1c:0a88 class-ID: 0300
API: ALSA v: k6.12.9-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0033
Local Storage: total: 31.91 TiB used: 13.76 TiB (43.1%)
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624331WD temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Micron model: 2400 MTFDKBA1T0QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA003 temp: 38.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HUH721010ALE604
size: 18.19 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 7200
serial: <filter> scheme: GPT
model: WD100EMAZ-00WJTA0 size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 3004 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 2.0
size: 58.61 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: MBR
used: 118.56 GiB (12.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 62.6 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 50.8 C mobo: N/A
Fan Speeds (rpm): cpu: 800
Memory: total: 64 GiB available: 62.6 GiB used: 6.63 GiB (10.6%)
Processes: 552 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.99 GiB services: org_kde_powerdevil,
Packages: 1916 pm: pacman pkgs: 1903 libs: 549 tools: octopi,paru
pm: flatpak pkgs: 13 Compilers: clang: 19.1.6 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-01-16
Last full system update: 2025-01-22 ↻
