Every time I launch a Proton game (Spelunky 2), it fails to start. Tried tkg, experimental, 5.10. I feel like a dependency is missing. Nvidia proprietary. This occurs with all Proton, non-native games.
This has not occured on my ol distro.
This is output after launching Spelunky 2 in steam via terminal:
(steam:102833): LIBDBUSMENU-GLIB-WARNING **: 20:11:52.577: Trying to remove a child that doesn't believe we're it's parent.
[0105/201152.590598:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0105/201152.590935:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0105/201152.596612:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Installing breakpad exception handler for appid(steam)/version(1609845358)
BuildCompleteAppOverviewChange: 1521
RegisterForAppOverview 1: 106ms
RegisterForAppOverview 2: 110ms
ExecuteSteamURL: "steam://open/downloads"
[0105/201202.146397:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 25
[0105/201202.152325:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 27
[0105/201202.205299:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 39
[0105/201202.211568:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 35
[0105/201202.219137:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 37
[0105/201202.223557:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 45
[0105/201202.226933:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 49
[0105/201202.236341:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 41
[0105/201202.244532:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 47
[0105/201202.249887:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 51
[0105/201202.251497:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 43
[0105/201202.267627:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 53
[0105/201202.283245:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 75
[0105/201202.285254:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 79
[0105/201202.286495:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 65
[0105/201202.287711:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 69
[0105/201202.290367:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 73
[0105/201202.294594:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 63
[0105/201202.297090:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 83
[0105/201202.300630:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 71
[0105/201202.302160:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 81
[0105/201202.303708:WARNING:spdy_session.cc(3316)] Received HEADERS for invalid stream 87
[418530]Non-Steam Controller Configs Enabled: 1
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
_v2-entry-point[104729]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[104730]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[104730]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[104729]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[104730]: XDG_RUNTIME_DIR=/run/user/1000
_v2-entry-point[104729]: XDG_RUNTIME_DIR=/run/user/1000
fsync: up and running.
_v2-entry-point[107623]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[107623]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[107623]: XDG_RUNTIME_DIR=/run/user/1000
_v2-entry-point[107682]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[107682]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[107682]: XDG_RUNTIME_DIR=/run/user/1000
vkBasalt err: no good config file
_v2-entry-point[107984]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[107984]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[107984]: XDG_RUNTIME_DIR=/run/user/1000
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 418530, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 418530, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 418530: 0
Game update: AppID 418530 "", ProcID 108003, IP 0.0.0.0:0
Starting app 418530
>>> Adding process 108003 for game ID 418530
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 418530, ActionID 1] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/ozy/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
pid 108010 != 108008, skipping destruction (fork without exec?)
>>> Adding process 108008 for game ID 418530
_v2-entry-point[108008]: STEAM_COMPAT_APP_ID=418530
_v2-entry-point[108008]: STEAM_COMPAT_SESSION_ID=dd7836cb40dcf087
_v2-entry-point[108008]: XDG_RUNTIME_DIR=/run/user/1000
>>> Adding process 108009 for game ID 418530
>>> Adding process 108011 for game ID 418530
>>> Adding process 108012 for game ID 418530
>>> Adding process 108013 for game ID 418530
pid 108023 != 108008, skipping destruction (fork without exec?)
>>> Adding process 108014 for game ID 418530
>>> Adding process 108026 for game ID 418530
>>> Adding process 108042 for game ID 418530
>>> Adding process 108043 for game ID 418530
ERROR: ld.so: object '/home/ozy/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
>>> Adding process 108151 for game ID 418530
>>> Adding process 108173 for game ID 418530
>>> Adding process 108216 for game ID 418530
>>> Adding process 108242 for game ID 418530
>>> Adding process 108276 for game ID 418530
>>> Adding process 108391 for game ID 418530
>>> Adding process 108416 for game ID 418530
Game update: AppID 418530 "", ProcID 108151, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 108151): SteamUtils009 / Utils
Setting breakpad minidump AppID = 418530
RecordSteamInterfaceCreation (PID 108151): SteamUser019 / User
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198005130199 [API loaded no]
RecordSteamInterfaceCreation (PID 108151): SteamFriends015 / Friends
RecordSteamInterfaceCreation (PID 108151): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 108151): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 108151): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 108151): STEAMAPPS_INTERFACE_VERSION008 / Apps
RecordSteamInterfaceCreation (PID 108151): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 108151): STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
RecordSteamInterfaceCreation (PID 108151): STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
RecordSteamInterfaceCreation (PID 108151): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 108151): SteamController006 / Controller
RecordSteamInterfaceCreation (PID 108151): STEAMUGC_INTERFACE_VERSION010 / UGC
RecordSteamInterfaceCreation (PID 108151): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 108151): STEAMMUSIC_INTERFACE_VERSION001 / Music
RecordSteamInterfaceCreation (PID 108151): STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
RecordSteamInterfaceCreation (PID 108151): STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
RecordSteamInterfaceCreation (PID 108151): STEAMINVENTORY_INTERFACE_V002 / Inventory
RecordSteamInterfaceCreation (PID 108151): STEAMVIDEO_INTERFACE_V002 / Video
RecordSteamInterfaceCreation (PID 108151): STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
>>> Adding process 108441 for game ID 418530
Game update: AppID 418530 "", ProcID 108441, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 108441): SteamUtils010 /
RecordSteamInterfaceCreation (PID 108441): SteamUser021 / User
SteamInternal_SetMinidumpSteamID: Caching Steam ID: 76561198005130199 [API loaded no]
RecordSteamInterfaceCreation (PID 108441): SteamFriends017 /
RecordSteamInterfaceCreation (PID 108441): STEAMAPPS_INTERFACE_VERSION008 /
RecordSteamInterfaceCreation (PID 108441): STEAMUSERSTATS_INTERFACE_VERSION012 /
Unable to read VR Path Registry from C:\users\steamuser\Local Settings\Application Data\openvr\openvrpaths.vrpath
pid 108186 != 108173, skipping destruction (fork without exec?)
Game removed: AppID 418530 "", ProcID 108441
Game 418530 created interface STEAMAPPS_INTERFACE_VERSION008 /
Game 418530 created interface STEAMUSERSTATS_INTERFACE_VERSION012 /
Game 418530 created interface SteamFriends017 /
Game 418530 created interface SteamUser021 /
Game 418530 created interface SteamUser021 / User
Game 418530 created interface SteamUtils010 /
Game 418530 method call count for IClientUser::GetSteamID : 2
Game 418530 method call count for IClientFriends::GetPersonaName : 1
Game 418530 method call count for IClientUtils::GetAppID : 7
Game 418530 method call count for IClientUtils::RecordSteamInterfaceCreation : 6
Game 418530 method call count for IClientAppManager::GetLaunchCommandLine : 1
Game 418530 method call count for IClientUserStats::RequestCurrentStats : 1
Uploaded AppInterfaceStats to Steam
Exiting app 418530
No cached sticky mapping in ActivateActionSet.
inxxi:
System: Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive BOOT_IMAGE=/vmlinuz-linux-tkg-bmq
root=UUID=6883504c-e6e7-4247-8478-121ea2485f7b rw [email protected] quiet splash
resume=UUID=d6c7d958-5138-489d-bb29-5db1e1a8a5fa loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: Gigabyte model: H97-HD3 v: x.x serial: <filter> BIOS: American Megatrends
v: F5 date: 06/26/2014
CPU: Info: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57660
Speed: 3556 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3556 2: 3595 3: 3592 4: 3574
5: 3353 6: 3427 7: 3601 8: 3601
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Gigabyte
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
Device-2: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 92 s-size: 994x301mm (39.1x11.9") s-diag: 1039mm (40.9")
Monitor-1: DVI-I-1 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: DVI-D-0 res: 1680x1050 dpi: 91 size: 470x300mm (18.5x11.8") diag: 558mm (22")
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
Device-2: Intel 9 Series Family HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:8ca0
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK CMI8786 driver: snd_oxygen
v: kernel bus ID: 05:01.0 chip ID: 13f6:8788
Device-4: Audient iD4 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-3:2
chip ID: 2708:0003
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8168
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Drives: Local Storage: total: 3.75 TiB used: 214.04 GiB (5.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G size: 111.79 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: BBF0
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-19ZF5A0 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0A80
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD30EZRX-00D8PB0 size: 2.73 TiB
Partition: ID-1: / raw size: 103.72 GiB size: 103.72 GiB (100.00%) used: 42.46 GiB (40.9%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-2: /boot raw size: 248 MiB size: 244.2 MiB (98.46%) used: 69.2 MiB (28.3%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw size: 2.73 TiB size: 2.73 TiB (100.00%) used: 171.52 GiB (6.1%) fs: btrfs
dev: /dev/sdc1 maj-min: 8:33
ID-4: /var/log raw size: 103.72 GiB size: 103.72 GiB (100.00%) used: 42.46 GiB (40.9%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-5: /var/tmp raw size: 103.72 GiB size: 103.72 GiB (100.00%) used: 42.46 GiB (40.9%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 1.94 GiB used: 336 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.94 GiB used: 312 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.94 GiB used: 212 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.94 GiB used: 280 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.94 GiB used: 400 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.94 GiB used: 508 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.94 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.94 GiB used: 256 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 61 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info: Processes: 331 Uptime: 33m wakeups: 0 Memory: 15.5 GiB used: 7.15 GiB (46.1%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 Packages: 1854 pacman: 1849 lib: 542 flatpak: 5 Shell: Zsh
v: 5.8 running in: konsole inxi: 3.2.01
