Proton does not want to share resources with other programs
When im trying to run steam game with proton and then minimaze game and i open discord or firefox i have 10 fps on discord or firefox. Pls help
Kernel: 6.15.9-zen1-1.1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=e10e3970-d3ca-4b36-b813-ac0477d616b8 rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FX506LI.310
date: 11/26/2021
ID-1: BAT1 charge: 29.2 Wh (100.0%) condition: 29.2/48.2 Wh (60.6%)
volts: 12.2 min: 11.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0x100
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 575.64.05 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f95
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56a2
display-ID: 0
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res:
mode: 1920x1080 hz: 144 scale: 120% (1.2) to: 1600x900 dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
device-ID: 8086:9bc4 memory: 61.16 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 25.1.7-arch1.1
device-ID: 8086:9bc4 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 Ti driver: nvidia v: 575.64.05
device-ID: 10de:1f95 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: Logitech PRO X Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 046d:0aba class-ID: 0300
API: ALSA v: k6.15.9-zen1-1.1-zen status: kernel-api with: aoss
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
Local Storage: total: 1.4 TiB used: 44.01 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Kingston model: OM8PCP3512F-AB
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.3 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3.2.F.2A temp: 34.9 C scheme: GPT
used: 44.01 GiB (4.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 620 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 57.0 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.63 GiB used: 3.82 GiB (6.1%)
Processes: 305 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.94 GiB services: org_kde_powerdevil,
Packages: 1856 pm: pacman pkgs: 1840 libs: 538 tools: octopi,paru
pm: flatpak pkgs: 16 Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash
v: 5.3.3 default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.5-1):
System install date:     2025-06-10
Last full system update: 2025-08-12
20/21 checks run in 0.50 seconds ⌛
Powered by garuda-health 🦅
Post the terminal output from garuda-inxi as requested in the template for your post. Without this output, it will be unnecessarily difficult to help you.
I don’t use Discord myself, but I know that this is a known issue.
Hello and Welcome,
if you would post it in here : https://forum.garudalinux.org/c/issues-assistance/15 you would get more viewers and helpers not in Games just a idea :wink:
It’s fine here, because I moved it here :smiley:
Have you tried this with a really lightweight game? I’m wondering if the laptop can barely run the game as is and gets bogged down trying to do other things.
That’s my first guess anyways.
Are you running your game with prime-run or are you starting your game without any extra launch parameters?
Without any launch parameters, the game will start on your integrated Intel GPU, which is probably unable to keep pace with the game and your OS UI at the same time.
It didn’t help
These games run normally on Windows
Pls post pacman -Qs nvidia
That you really know if your dgpu (nvidia) is in use, start game → open konsole →
nvidia-smi and post the result
This statement doesn’t help anyone. Describe exactly what happens, whether there are error messages, etc.
Ya again, more useless info. Nobody on Linux forum’s gives a tinkers damn about Windows.
which steam game your running ? did you checked the proton db site? which wine your using?
