Proper way to mount my Windows drive on boot (for high speed write)
I am getting low write speeds (~50MB/s) on my NTFS drive (SSD), Which is also the drive on which Windows is installed on. I heard that including big_write in fstab might help with speed, but it can also corrupt the partition. Any suggestions?
My fstab entry for the NTFS drive:
UUID=48103B67103B5B60                       /run/media/rps/win   ntfs-3g    users                                                    0 0
System info:
Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=9ac760ab-99f5-4de2-a9c4-22b8b2157009 rw rootflags=subvol=@
resume=UUID=a7497668-1f06-42e7-a77a-3efe8a5f6004 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.331 date: 02/24/2023
ID-1: BAT0 charge: 51.9 Wh (60.0%) condition: 86.5/90.0 Wh (96.1%)
volts: 15.7 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1199 high: 1200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1200 2: 1200
3: 1198 4: 1200 5: 1200 6: 1200 7: 1198 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 102206
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
compositor: kwin_x11 driver: X: loaded: modesetting dri: radeonsi
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Acer B246WL
serial: <filter> built: 2020 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x8294 built: 2020
res: 1920x1200 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.10-zen2-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
Device-4: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 3-1.1.1:6 chip-ID: 0c76:1620 class-ID: 0300
API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 8087:0029
Local Storage: total: 2.33 TiB used: 731.23 GiB (30.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 40.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
used: 146.11 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
ID-4: /var/log raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.08 GiB size: 460.08 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:6
ID-2: swap-2 type: zram size: 30.77 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 396 Uptime: 2m wakeups: 7 Memory: total: 32 GiB note: est.
available: 30.77 GiB used: 2.98 GiB (9.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2070 libs: 561 tools: octopi,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-18
Last full system update: 2023-08-22
