Hi, It’s my first topic.
My garuda-inxi:
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1b079d8b-58a3-4533-8245-22b97207f1e1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
Mobo: Gigabyte model: Z390 AORUS PRO-CF serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F13 date: 12/21/2023
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x100
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
bogomips: 115200
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Gigabyte
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: DP-2,DP-3
empty: DP-1,HDMI-A-1,Unknown-2 bus-ID: 01:00.0 chip-ID: 10de:1e81
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 3926x1440 s-dpi: 108 s-size: 923x342mm (36.34x13.46")
s-diag: 984mm (38.75")
Monitor-1: DP-2 note: disabled pos: primary,top-right
model: Asus ROG PG279Q serial: <filter> built: 2017 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
Monitor-2: DP-3 mapped: DP-5 note: disabled pos: bottom-l
model: Philips 191EL serial: <filter> built: 2010 res: 1366x768 hz: 60
dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06") diag: 470mm (18.5")
ratio: 16:9 modes: max: 1366x768 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2080 SUPER driver: nvidia v: 560.35.03 device-ID: 10de:1e81
surfaces: xcb,xlib
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
Device-2: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 3.18 TiB used: 1.23 TiB (38.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P4CR313 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
used: 157.43 GiB (33.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 596 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 36.0 C pch: 37.0 C mobo: N/A gpu: nvidia
temp: 42 C
Memory: total: 32 GiB available: 31.27 GiB used: 2.84 GiB (9.1%)
Processes: 388 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1974 libs: 574 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-08-17
Last full system update: 2024-09-26
It is not really a problem, but rather a nuisance, a degradation of the quality of life? I don’t know. That’s why I post it here.
Every time I start, my login screen, it pops up with the pormpt to type my password on the wrong screen, the one on the left, when my main screen is the one right in front of me. In the picture, I indicate it with a red arrow (wrong place):
I would like to write, my password, on the center screen (Asus 27"). I know that more than one will think “what’s the difference” is just to write the password, but for me it is to get knowledge of how Linux works in the boot process. I know that the X server has to start first, then the window manager, in my case KWin. I have followed the Display Manager multi-monitor configuration tutorial, it is excellent, I also read on the ArckWiki Multihead, as well as other sources and places on the internet, but there is something that escapes me because I either don’t know or didn’t understand it and I can’t get my 27” screen to be the primary (I think it is called that). Below is my dm-multimonitor.sh file:
File: /etc/X11/xorg.conf.d/dm-multimonitor.sh
#!/bin/sh
# get the correct actual monitor names with
# xrandr | awk ' /connected/ { print $1, $2 }'
mon1=DP-2
mon2=DP-5
# wait 3
if xrandr | grep "$mon2 disconnected"; then
xrandr --output "$mon2" --off --output "$mon1" --auto
elif xrandr | grep "$mon1 disconnected"; then
xrandr --output "$mon1" --off --output "$mon2" --auto
else
xrandr --output "$mon1" --primary --mode 2560x1440 --pos 1366x0 --output "$mon2" --mode 1366x768 --pos 0x672
fi
If anyone can point me to where I can find the information related to this, I would appreciate it.
