My problem is, that after i restart a program, the volume is back to 100%
I start a program, i put it on 20%, close it and start it again and it is again on 100%
root=UUID=38add348-b329-4341-8751-7bbc309d28a1 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=0 loglevel=3
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends v: B.40
date: 11/07/2019
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4165 high: 4173 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4169 2: 4156
3: 4162 4: 4168 5: 4173 6: 4157 7: 4167 8: 4169 9: 4164 10: 4171 11: 4173
12: 4151 bogomips: 91201
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Tul / PowerColor driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 2b:00.0 chip-ID: 1002:731f class-ID: 0300
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Asus VP228
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: BenQ GL2706PQ serial: <filter> built: 2016 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
OpenGL: renderer: AMD Radeon RX 5600 XT (navi10 LLVM 13.0.1 DRM 3.44
5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2b:00.1 chip-ID: 1002:ab38
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media CM108 Audio Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4 chip-ID: 0d8c:013c
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8811AU 802.11a/b/g/n/ac WLAN Adapter type: USB
driver: rtl88XXau bus-ID: 1-3:3 chip-ID: 0bda:a811 class-ID: 0000
IF: wlp3s0f0u3 state: up mac: <filter>
IF-ID-1: enp3s0f0u1 state: unknown speed: -1 duplex: half mac: <filter>
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-4: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-5: virbr0 state: down mac: <filter>
Device-1: Spreadtrum W_K120 type: USB driver: rndis_host v: kernel
bus-ID: 1-1:10 chip-ID: 1782:5d21 class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 3.18 TiB used: 832.69 GiB (25.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA300
type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 750 EVO 500GB
ID-1: / raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
used: 173.79 GiB (38.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-4: /var/log raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.27 GiB size: 448.27 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.2 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.63 GiB used: 1.65 GiB (10.5%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 60.0 C
Processes: 431 Uptime: 7h 39m wakeups: 0 Memory: 15.63 GiB
used: 8.52 GiB (54.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: apt: 0 pacman: 2373 lib: 532
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-01-14
Last full system update: 2022-04-12
Failed units: bluetooth-autoconnect.service systemd-oomd.socket```
