To my surprise, I discovered this afternoon that /proc/cpuinfo is empty on my computer. It turns out that garuda-inxi includes the information I was looking for (instruction set support), but there may well be programs or scripts that look in /proc/cpuinfo, so I'd still like to have it populated. Any help is appreciated.
ls output:
.r--r--r-- 0 root 22 Dec 16:59 /proc/cpuinfo
garuda-inxi output:
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=175bf059-bdac-45c1-a3c9-14741ad4fc89 rw [email protected]
loglevel=3 ibt=off
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X300-ITX serial: <superuser required>
UEFI: American Megatrends LLC. v: P1.40 date: 08/02/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2092 high: 3900 min/max: 1400/4464 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3082 2: 1400
3: 1400 4: 3900 5: 1400 6: 1400 7: 3030 8: 1400 9: 1400 10: 1400 11: 1400
12: 3900 bogomips: 93423
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ff
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
gpu: amdgpu display-ID: 0
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 6600 (navi23 LLVM
14.0.6 DRM 3.49 6.1.1-zen1-1-zen) direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
v: 0.8 bus-ID: 1-2:2 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 4.55 TiB used: 1.2 TiB (26.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-2000GM size: 1.82 TiB block-size: physical: 512 B
rev: 31060C20 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
type: SSD serial: <filter> rev: 045 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Smart Modular Tech.
model: SHGS31-500GS-2 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD5000BEVT-00A0RT0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1.75 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 592.64 GiB (31.8%)
used: 592.64 GiB (31.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.67 GiB used: 630.2 MiB (1.0%)
System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 2119 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 0
Processes: 337 Uptime: 2d 23h 29m wakeups: 0 Memory: 62.67 GiB
used: 4.45 GiB (7.1%) Init: systemd v: 252 default: graphical
pkgs: 1886 libs: 455 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-11-17
Last full system update: 2022-12-25 ↻
