Problems with Uploading in Chromium and Opera
Help please.
when i trying to upload any files at any sources in Opera or Chromium nothing happens…
“telegram web” have the same problems… in the App Telegram all fine.
xdg-desktop-portal-kde installed
LANGUAGE = "",
LC_ALL = (unset),
LC_CTYPE = (unset),
LC_NUMERIC = "ru_RU.UTF-8",
LC_COLLATE = (unset),
LC_TIME = "ru_RU.UTF-8",
LC_MESSAGES = (unset),
LC_MONETARY = "ko_KR.UTF-8",
LC_ADDRESS = "ru_RU.UTF-8",
LC_IDENTIFICATION = "ru_RU.UTF-8",
LC_MEASUREMENT = "ru_RU.UTF-8",
LC_PAPER = "ru_RU.UTF-8",
LC_TELEPHONE = "ko_KR.UTF-8",
LC_NAME = "ru_RU.UTF-8",
LANG = "ru_RU.UTF-8"
perl: warning: Falling back to a fallback locale ("ru_RU.UTF-8").
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c81a4860-6ad9-4310-b9aa-7b437773a420 rw rootflags=subvol=@
resume=UUID=68089b85-7e2d-4da0-a5c4-25e3997f732f loglevel=3
clearcpuid=514 ibt=off
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
UEFI: American Megatrends v: 2806 date: 10/27/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 550 min/max: 550/5278 boost: disabled scaling:
driver: amd-pstate-epp governor: performance,powersave cores: 1: 550 2: 550
3: 550 4: 550 5: 550 6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550
bogomips: 100804
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
HDMI-A-1, Writeback-1 bus-ID: 0a:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
navi22 LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.295 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
bus-ID: 0a:00.1 chip-ID: 1002:ab28 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
Local Storage: total: 2.27 TiB used: 327.45 GiB (14.1%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
fw-rev: 4B2QEXM7 temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-1: / raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
used: 327.44 GiB (73.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
ID-4: /var/log raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 811.2 MiB (10.4%)
ID-2: swap-2 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.6 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 58.0 C
Memory: total: 8 GiB available: 7.63 GiB used: 3.4 GiB (44.5%)
Processes: 339 Power: uptime: 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.03 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1983 libs: 595 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
System install date:     2023-08-05
Last full system update: 2024-11-03 ↻
P.S. It was that since installing the garuda
Welcome to the forum
Please can you provide your
garuda -inxi
As per the forum template
sorry, info was added
Start web browser(s) from terminal and read the log, maybe filter in Kate the errors.
But it can also be that your ISP block it.
ko_KR. Korean (UTF-8),
ru_RU. Russian (UTF-8),
↻ means restart the PC, it’s KDE
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
[6897:6952:1103/005033.534023:ERROR:display.cc(191)] Frame latency is negative: -2.414 ms
[6897:6897:1103/005048.050230:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
[6897:6897:1103/005048.051416:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
[6897:6897:1103/005054.506056:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
tryed launch as root too
╭─grooty@grooty in ~ took 55s
╰─λ sudo chromium
[sudo] password for grooty:
[8969:8969:1103/005245.271918:ERROR:zygote_host_impl_linux.cc(101)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
╭─grooty@grooty in ~ as 🧙 took 4s
[🔴] × sudo chromium --no-sandbox
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
[9206:9221:1103/005259.589329:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005259.589362:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005259.589448:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005259.589517:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005259.589573:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
Authorization required, but no authorization protocol specified
[9248:9248:1103/005259.626854:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
ERR: Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9248:9248:1103/005259.626924:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9248:9248:1103/005259.626956:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9248:9248:1103/005259.627049:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9248:9248:1103/005259.627084:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9248:9248:1103/005259.627113:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9248:9248:1103/005259.627142:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9248:9248:1103/005259.627169:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9248:9248:1103/005259.640162:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9248:9248:1103/005259.640211:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9248:9248:1103/005259.640239:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9248:9248:1103/005259.640319:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9248:9248:1103/005259.640352:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9248:9248:1103/005259.640379:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9248:9248:1103/005259.640406:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9248:9248:1103/005259.640432:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9248:9248:1103/005259.641179:ERROR:viz_main_impl.cc(181)] Exiting GPU process due to errors during initialization
[9206:9206:1103/005259.923022:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005259.923042:ERROR:kwallet_dbus.cc(117)] Error contacting kwalletd (isEnabled)
[9206:9206:1103/005259.923064:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005259.923068:ERROR:kwallet_dbus.cc(86)] Error contacting klauncher to start kwalletd
[9206:9206:1103/005259.923079:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005259.923083:ERROR:kwallet_dbus.cc(412)] Error contacting kwalletd (close)
[9206:9221:1103/005259.933242:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005259.933260:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9217:1103/005300.097722:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005300.108098:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9221:1103/005300.108120:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005300.158030:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[9206:9220:1103/005300.158102:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005300.165621:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[9206:9220:1103/005300.165707:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005300.168454:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[9206:9220:1103/005300.168496:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005300.169027:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[9206:9220:1103/005300.169064:ERROR:bus.cc(407)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9206:9206:1103/005300.169282:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[9311:9311:1103/005300.169328:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9311:9311:1103/005300.169405:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9311:9311:1103/005300.169437:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9311:9311:1103/005300.169552:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9311:9311:1103/005300.169591:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9311:9311:1103/005300.169620:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9311:9311:1103/005300.169649:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9311:9311:1103/005300.169675:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9311:9311:1103/005300.182586:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9311:9311:1103/005300.185565:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9311:9311:1103/005300.185618:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9311:9311:1103/005300.185754:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9311:9311:1103/005300.185800:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9311:9311:1103/005300.185834:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9311:9311:1103/005300.185865:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9311:9311:1103/005300.185905:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9311:9311:1103/005300.186844:ERROR:viz_main_impl.cc(181)] Exiting GPU process due to errors during initialization
[9408:9408:1103/005300.210290:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9408:9408:1103/005300.210351:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9408:9408:1103/005300.210378:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9408:9408:1103/005300.210472:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9408:9408:1103/005300.210549:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9408:9408:1103/005300.210580:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9408:9408:1103/005300.210640:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9408:9408:1103/005300.210673:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9408:9408:1103/005300.221820:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9408:9408:1103/005300.221881:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9408:9408:1103/005300.221906:ERROR:gl_display.cc(767)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[9408:9408:1103/005300.221988:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Could not open the default X display.
[9408:9408:1103/005300.222022:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Could not open the default X display.
[9408:9408:1103/005300.222046:ERROR:gl_display.cc(767)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[9408:9408:1103/005300.222072:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9408:9408:1103/005300.222096:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9408:9408:1103/005300.222830:ERROR:viz_main_impl.cc(181)] Exiting GPU process due to errors during initialization
[9463:9463:1103/005300.244037:ERROR:angle_platform_impl.cc(44)] DisplayVkXcb.cpp:58 (initialize): xcb_connect() failed, error 1
ERR: DisplayVkXcb.cpp:58 (initialize): xcb_connect() failed, error 1
[9463:9463:1103/005300.244090:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Not initialized.
ERR: Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[9463:9463:1103/005300.244121:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Not initialized.
[9463:9463:1103/005300.244146:ERROR:gl_display.cc(767)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[9463:9463:1103/005300.244170:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9463:9463:1103/005300.244197:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9463:9463:1103/005300.254813:ERROR:angle_platform_impl.cc(44)] DisplayVkXcb.cpp:58 (initialize): xcb_connect() failed, error 1
[9463:9463:1103/005300.254857:ERROR:angle_platform_impl.cc(44)] Display.cpp:1083 (initialize): ANGLE Display::initialize error 12289: Not initialized.
[9463:9463:1103/005300.254890:ERROR:gl_display.cc(497)] EGL Driver message (Critical) eglInitialize: Not initialized.
[9463:9463:1103/005300.254914:ERROR:gl_display.cc(767)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[9463:9463:1103/005300.254939:ERROR:gl_display.cc(801)] Initialization of all EGL display types failed.
[9463:9463:1103/005300.254961:ERROR:gl_ozone_egl.cc(26)] GLDisplayEGL::Initialize failed.
[9463:9463:1103/005300.255675:ERROR:viz_main_impl.cc(181)] Exiting GPU process due to errors during initialization
[9474:9487:1103/005300.276381:ERROR:x11_software_bitmap_presenter.cc(150)] XGetWindowAttributes failed for window 33554436
IDK, first try to fix it.
Never use root for such applications like browsers.
Don’t you have to set them to wayland mode now days as chrome based use xwaland and are still broken. Does the same thing happen on firefox?
WOW… i was used only Opera and Chromium
Now check FireDragon and there is all OK
so they have a solution for Chromium?
was try to change to wayland, didnt work…
Go to chrome://flags
Search "Preferred Ozone platform"
Set it to "Wayland"
Restart
I can’t say if they have a real solution yet. As I don’t use blink based browsers. But maybe someone has one out there.
Anyone have those problems or its only mine trouble?
