Hi, I haven’t been able to figure out this problem for a long time.
I’ve never been able to get my printer’s scanner to work in Garuda, I’ve tried with all available drivers.
While under Pi OS in my Raspberry it works fine using the Fuji-Xerox-Docuprint-CM305 drivers I tried this morning, on both systems I tried Skanlite.
The printer is on the network under 192.168.0.250
Can you give me some clues as to what I’m doing wrong?
Thank you.
Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=671de9f9-8ee6-4c92-a404-549bf7935a22 rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5013 date: 03/22/2024
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2598 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3800 2: 2880
3: 2200 4: 2200 5: 2200 6: 2200 7: 3800 8: 3800 9: 2200 10: 2200 11: 2200
12: 2200 13: 3088 14: 2200 15: 2200 16: 2200 bogomips: 121593
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ZOTAC driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0a:00.0
chip-ID: 10de:2782 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
chip-ID: 0c45:8006 class-ID: 0301
Device-3: Sunplus Innovation Aukey-PC-LM1E Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1:2 chip-ID: 1bcf:0215 class-ID: 0102
d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-1 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2782
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM 18.1.8)
Device-1: NVIDIA AD104 High Definition Audio vendor: ZOTAC
bus-ID: 0a:00.1 chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.9.9-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:4
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 10.01 TiB used: 273.64 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Smart Modular Tech.
model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.2 temp: 28.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
used: 273.64 GiB (29.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 50.0 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 4.48 GiB (14.3%)
Processes: 367 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1773 libs: 454
tools: octopi,paru,yay pm: rpm pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-01-21
Last full system update: 2024-07-14
Failed units: samba.service
