Hello, today suddenly my audio stopped working, not with wire not with bluetooth. As well as youtube stopped loading videos at all, yet other websites load no problem, i checked it on 2 web browsers, my other windows computer has no issue with youtube so its something with garuda. I think it happened right after an update and i have no clue why. I tried restarting, it didnt work.
Kernel: 6.1.5-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6c7d3ca4-1512-42b2-93c9-c275ec6e0f08 rw [email protected]
quiet splash intel_pstate=disable quiet quiet splash
Type: Convertible System: LENOVO product: 82HS v: IdeaPad Flex 5 14ITL05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ITL05
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
serial: <superuser required> UEFI: LENOVO v: FXCN28WW date: 04/27/2021
ID-1: BAT0 charge: 49.3 Wh (93.7%) condition: 52.6/52.5 Wh (100.2%)
volts: 12.6 min: 11.5 model: Celxpert L19C3PD6 type: Li-poly
serial: <filter> status: discharging cycles: 19
Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX
Anywhere 2 serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: discharging
Device-2: wacom_battery_0 model: Wacom HID 5213 serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1080 high: 1100 min/max: 400/2401 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1100 2: 1063
3: 1100 4: 978 5: 1100 6: 1100 7: 1100 8: 1100 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:3
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 model: BOE Display 0x08d9 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.1.5-zen2-1-zen running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 476.94 GiB used: 58.76 GiB (12.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
lanes: 4 type: SSD serial: <filter> rev: 0011P6LN temp: 44.9 C scheme: GPT
used: 58.76 GiB (12.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.32 GiB used: 22 MiB (0.3%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 270 Uptime: 8m wakeups: 707 Memory: 7.32 GiB
used: 4.02 GiB (54.8%) Init: systemd v: 252 default: graphical
pkgs: 1463 libs: 443 tools: gnome-software,octopi,pamac,paru Shell: fish
v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-07
Last full system update: 2023-01-13
Windows dual boot: no
Operating System: Garuda Linux
KDE Plasma Version: 5.26.5
KDE Frameworks Version: 5.101.0
Qt Version: 5.15.8
Kernel Version: 6.1.5-zen2-1-zen (64-bit)
Graphics Platform: X11
Processors: 8 × 11th Gen Intel® Core™ i5-1135G7 @ 2.40GHz
Memory: 7.3 ГиБ of RAM
Graphics Processor: Mesa Intel® Xe Graphics
Manufacturer: LENOVO
Product Name: 82HS
System Version: IdeaPad Flex 5 14ITL05
