Hello, I have been having problems since the day I downloaded the system:
- High CPU usage by kwin_wayland
- Problems with NVIDIA drivers (60 HZ and locked options)
Please help, it is annoying me slowly
Hello Garuda users.
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
Find out what steps to take in order to find a solution to a problem
Hello,
This OS looks cool enough for me to create a forum account, unfortunately i just installed and updated. I cant seem to get the integrated Intel Graphics driver to work along with the mobile NVidia 1660TI. kwin_wayland is using about 80 percent CPU and the mouse is non-reposnsive. I loaded the propietary drivers using the documentation on this forum. however, the OS doesnt seem to recognize the integrated Intel graphics. here is my config.
root=UUID=1bf77660-b47c-4d9f-9f6f-49927f62e38d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 81Q6 v: Legion Y545
serial: <superuser required> Chassis: type: 10 v: Legion Y545
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: BHCN32WW date: 08/29/2019
ID-1: BAT0 charge: 41.1 Wh (100.0%) condition: 41.1/57.0 Wh (72.1%)
volts: 12.6 min: 11.5 model: SMP L17M3PG2 type: Li-poly serial: <filter>
status: full cycles: 33
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1000 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1000 2: 1000 3: 1000 4: 1000 5: 1000 6: 1000
7: 1000 8: 1000 9: 1000 10: 1000 11: 1000 12: 1000 bogomips: 62399
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 04f2:b6d9
compositor: kwin_wayland driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: 1920x1080 size: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia wayland:
drv: swrast x11: drv: swrast inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.17 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 545.29.02 device-ID: 10de:2191
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA TU116 High Definition Audio vendor: Lenovo
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
Local Storage: total: 1.38 TiB used: 18.82 GiB (1.3%)
model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 3L1QEXF7 temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE0010PNC
tech: SSD serial: <filter> fw-rev: 30WD scheme: GPT
used: 18.82 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 79.0 C pch: 67.0 C mobo: N/A
Processes: 278 Uptime: 10m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 2.63 GiB (16.9%) Init: systemd v: 254
pm: pacman pkgs: 1806 libs: 531 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-20
Last full system update: 2023-11-20
Failed units: systemd-backlight@backlight:nvidia_0.service
Are you sure the BIOS is not set to use only the dGPU? This would explain why the iGPU is not shown.
After fixing this, you should consider this:
I’m sorry that the thread was hijacked and I didn’t notice that.
