I have a bit of an issue integrating a previously functional NTFS-Formatted Harddrive into my system and i am on the look for a tip towards what I should research to get it back up and running:
I have a secondary NTFS-formatted Harddrive in my Laptop which I want to integrate into my freshly installed Garuda Dragonized Gamer. Previously this Harddrive contained datafiles required for programs running in my previously existing Windowsinstallation (including several dozen Gigabytes of Music, Samples and (backed-up) Projectfiles for FL Studio).
The drive didnt show up right away in Dolphin so I tried mounting via Commandline with
sudo mount /dev/sda /mnt/ntfs1/
to the directory /mnt/ntfs1/ which i created previously for exactly this purpose.
The Mount failed with following Notice:
wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or helper program, or other error
I looked up the drive in Partitionmanager, which reported an unknown fs-type. (Screenshot included)
sudo fdisk -l reported the following:
Festplatte /dev/sda: 931,51 GiB, 1000204886016 Bytes, 1953525168 Sektoren
Festplattenmodell: ST1000LM048-2E71
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 4096 Bytes
E/A-Größe (minimal/optimal): 4096 Bytes / 4096 Bytes
Festplattenbezeichnungstyp: gpt
Festplattenbezeichner: 500004F2-AAD2-4E81-9269-0E86E62B3BA0
Gerät Anfang Ende Sektoren Größe Typ
/dev/sda1 34 2081 2048 1M Microsoft LDM-Metadaten
/dev/sda2 2082 262177 260096 127M Microsoft reserviert
/dev/sda3 262178 1953525134 1953262957 931,4G Microsoft LDM-Daten
Partition 1 beginnt nicht an einer physikalischen Sektorgrenze.
Partition 2 beginnt nicht an einer physikalischen Sektorgrenze.
Partition 3 beginnt nicht an einer physikalischen Sektorgrenze.
(Partition x does not start at a physical Sectorborder)...
To make sure i did not somehow damage the FS i plugged the harddrive into my Windowsmachine, where it works fine, i can access and index all files + their contents.
Now my question would be: where did i f*** up in the process and how do I make sure i prevent this issue from happening again with other drives in the future?
