Problems with drivers and brightness
Greetings. I've swapped to Garuda Linux recently and experienced some problems with drivers and brightness.
My laptop has two GPUs: AMD Radeon 680M and NVIDIA RTX 3070 Ti mobile. Pacman tells that my nvidia drivers are "nvidia-dkms", however garuda-inxi tells that drivers are "nvidia". Even though, my brightness doesn't change a bit. FN keys are working and notification pops up when i press them ("brightness down or up") but still no change in brightness. xfce4-power-manager is running. Any help?
BTW, i'd really love to have some gui settings like garuda-settings-manager in here, as there are lots of settings which are not in there (display settings, touchpad settings or keyboard layouts) Do you know something I can do to have one?
my garuda-inxi
  Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=48a975a9-d344-4a46-b26f-070d8548fc9b rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 82RG v: Legion 5 Pro 16ARH7H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ARH7H
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> UEFI: LENOVO v: JUCN59WW date: 03/15/2023
  ID-1: BAT0 charge: 64.3 Wh (80.1%) condition: 80.3/80.0 Wh (100.4%)
    volts: 16.3 min: 15.4 model: BYD L21B4PC0 type: Li-poly serial: <filter>
    status: not charging cycles: 57
  Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1679 high: 2371 min/max: 1600/4784 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 2065
    3: 1600 4: 1600 5: 1600 6: 1595 7: 1596 8: 1378 9: 1596 10: 1600 11: 1596
    12: 1600 13: 1369 14: 1359 15: 2371 16: 2350 bogomips: 102206
  Device-1: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
    driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24e0 class-ID: 0300
  Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6 bus-ID: 34:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 50.0 C
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:115f
    class-ID: fe01
  Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a
    driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 676x422mm (26.61x16.61")
    s-diag: 797mm (31.37")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a9b built: 2020
    res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 2560x1600
    missing.
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 34:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 34:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.6
  API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
    port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0489:e0d8
    address: <filter>
  Local Storage: total: 953.87 GiB used: 12.16 GiB (1.3%)
    model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: CL1QGXA7 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
    used: 12.1 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 57.9 MiB (60.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
  ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
  ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%)
  ID-1: swap-1 type: zram size: 14.82 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 56.6 C mobo: N/A gpu: amdgpu temp: 54.0 C
  Processes: 411 Uptime: 1h 35m wakeups: 31204 Memory: available: 14.82 GiB
  used: 5.35 GiB (36.1%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1314
  libs: 351 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: kitty
  inxi: 3.3.27
  System install date:     2023-06-24
  Last full system update: 2023-06-25 ↻
If it’s not already installed, try brightnessctl. It is one of the easiest utilities available for this feature.
sudo pacman -S brightnessctl
This and plenty more solutions are documented here: Backlight - ArchWiki
Check out ARandR for a simple GUI display settings app.
i3 is sort of philosophically the opposite of what you are describing; GUI options are intentionally avoided in favor of allowing everything to be controlled in config files or command-line applications. Still, with some digging I’m sure you can get some good GUI apps set up for controlling your settings.
Hint: a lot of XFCE apps are likely to work, without pulling in half a distro worth of dependencies like you may find with Gnome or KDE apps.
