Hi,
I installed MangoHud as an option in Garuda Gamer.
However to check the program if it is working wel I get the following output with
mangohud glxgears:
[2024-04-21 21:25:26.167] [MANGOHUD] [error] [overlay_params.cpp:1003] Failed to read presets file: ‘/home/arthur/.config/MangoHud/presets.conf’
[2024-04-21 21:25:26.168] [MANGOHUD] [error] [overlay_params.cpp:840] Unknown option ‘engine’
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
and with mangohud vkcube:
[2024-04-21 21:26:43.293] [MANGOHUD] [error] [overlay_params.cpp:1003] Failed to read presets file: ‘/home/art
[2024-04-21 21:26:43.293] [MANGOHUD] [error] [overlay_params.cpp:840] Unknown option ‘engine’
Selected GPU 0: AMD Radeon RX 6800 XT (RADV NAVI21), type: DiscreteGpu
This is the MangoHud.conf file:
################### File Generated by Goverlay ###################
legacy_layout=false
background_alpha=0.6
round_corners=0
background_color=000000
font_size=24
text_color=FFFFFF
position=top-left
toggle_hud=Shift_R+F12
pci_dev=0:09:00.0
table_columns=3
gpu_text=GPU
gpu_stats
gpu_temp
cpu_text=CPU
cpu_temp
vram
vram_color=AD64C1
fps
engine
engine_color=EB5B5B
wine
wine_color=EB5B5B
fps_limit_method=late
toggle_fps_limit=Shift_L+F1
show_fps_limit
fps_limit=0
output_folder=/home/arthur
log_duration=30
autostart_log=0
log_interval=100
I’m sorry but my linux knowledge is very basic. Hope somebody can help me with this.
Thanks in advance with any help.
//Arthur
