Problems = update -
I have been getting the following message since yesterday
The following message is displayed -
No update possible:
Error
Process could not be prepared successfully.
Cannot fulfil dependencies:
removing appstream-qt violates …
Close
What is the cause?
According to Terminal ( sudo pacman -Syu …
Quote:
Warning: cryptomator: Local version (1.9.1-1) is newer than chaotic-aur (1.7.5-1)
Dependencies are resolved …
Conflicting packages are searched for …
Error: process could not be prepared (cannot fulfil dependencies)
:: Removing appstream-qt violates dependency “appstream-qt”, required by apper
Translated with DeepL Translate: The world's most accurate translator (free version)
AUR-client:
https://imgur.com/IMvm4Nn.png
thank you - best regards
Looked it up by now, seems it’s a KDE update client that uses package kit. Ewww, I’d get rid of that. Better use Octopi (since it uses native libraries).
Sorry,
have to do with
Terminal + sudo pacman -Sy appstream-qt
solved the problem.
Please delete - sorry again
thank you, best regards
That does not negate the fact you aught not be using it without expecting problems. Packagekit-qt5 is the same. :frowning:
Even if the issue was worked around, you should remove that apper. See:
