Sorry for posting in the wrong place, I’m not familiar with the forum and even less familiar with Arch, but if you give me a chance …
Apparently most of the options for Yandex-browser are out of date but I see that there is one, the one marked ‘1’ that seems to be ‘available’, but I just don’t understand how I should proceed after …
╭─alnone@alnone in ~ took 11ms
╰─λ LANG=C paru yandex-browser
5 aur/yandex-browser-ffmpeg-codecs-update-hook 0.0.1-1 [+0 ~0.00] [Out-of-date: 2023-01-09] [Orphaned]
alpm-hook to automatically update yandex-browser's ffmpeg codecs on package
update
4 aur/yandex-browser-corporate 24.1.3.843-1 [+0 ~0.00]
The web browser from Yandex. Yandex Browser is a browser that combines a
minimal design with sophisticated technology to make the web faster, safer,
and easier.
3 aur/yandex-browser-ffmpeg-codecs-opera 0.0.2-1 [+5 ~0.00] [Out-of-date: 2020-10-23] [Orphaned]
symlink for opera-ffmpeg-codecs package to be used with yandex-browser
2 aur/yandex-browser-beta 23.3.1.906_1-3 [+85 ~0.00] [Out-of-date: 2023-05-15]
and easier.
1 aur/yandex-browser 24.1.1.940-1 [+34 ~1.56]
and easier.
:: Packages to install (eg: 1 2 3, 1-3):
:: 1
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
Aur (1) Old Version New Version Make Only
aur/yandex-browser 24.1.1.940-1 No
:: Proceed to review? [Y/n]: Y
:: Downloading PKGBUILDs...
PKGBUILDs up to date
/home/alnone/.cache/paru/clone/yandex-browser/PKGBUILD
# Maintainer: Mikhail Velichko <efklid@gmail.com>
_pkgname=browser-stable
pkgname=yandex-browser
pkgver=24.1.1.940
_pkgver=24.1.1.940-1
pkgrel=1
#epoch=1
pkgdesc="The web browser from Yandex.
Yandex Browser is a browser that combines a minimal design with sophisticated >
arch=("x86_64")
url='https://browser.yandex.com/'
license=("custom:yandex-browser")
categories=("network")
provides=(yandex-browser)
conflicts=('yandex-browser' 'yandex-browser-stable')
options=(!strip)
depends=( "binutils" "ttf-liberation" "jq" "alsa-lib" "at-spi2-atk" "libcups" ">
"wayland" "libxcomposite" "libxdamage" "libxkbcommon" "libxkbfile" "libxrandr" >
optdepends=(
it seems to indicate that there are missing dependencies, but also that there are conflicts between the two versions of Yandex and that we have to compile (!strip) very confusing matter for me, if someone could please ,tell me what it all this means or how should I proceed, thank you.
╭─alnone@alnone in ~ took 12ms
╰─λ inxi -Faz
Kernel: 6.6.21-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=91c0a886-25fe-452a-b52b-00f0e5b90cbe rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: Dell product: Inspiron 3583 v: N/A
Mobo: Dell model: 0WHCP7 v: A00 serial: <superuser required> part-nu: 08CA
uuid: <superuser required> UEFI: Dell v: 1.5.1 date: 05/30/2019
ID-1: BAT0 charge: 39.9 Wh (100.0%) condition: 39.9/42.0 Wh (95.0%)
volts: 12.6 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
stepping: 0xC (12) microcode: 0xFA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 500 high: 800 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 800 6: 400 7: 800 8: 400 bogomips: 28808
Type: gather_data_sampling mitigation: Microcode
Type: spec_rstack_overflow status: Not affected
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
conditional, RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5520
Display: x11 server: X.Org v: 21.1.11 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2017 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.0.2-arch1.2
device-ID: 8086:3ea0 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.2 (LLVM
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.21-1-lts status: kernel-api tools: N/A
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 238.47 GiB used: 8.79 GiB (3.7%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20200012 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 48.48 GiB size: 48.48 GiB (100.00%) used: 8.76 GiB (18.1%)
ID-2: /boot/efi raw-size: 1.43 GiB size: 1.43 GiB (99.80%)
used: 27.1 MiB (1.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
used: 8.76 GiB (18.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.48 GiB size: 48.48 GiB (100.00%)
ID-1: swap-1 type: partition size: 1.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 38.0 C mobo: 33.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 8 GiB available: 7.63 GiB used: 2.49 GiB (32.7%)
Processes: 241 Power: uptime: 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1464 libs: 431 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
╭─alnone@alnone in ~ took 1s
╰─λ
