I’m failing to use some Qgis or Gdal features that call Python, having errors I’m not able to handle, since I don’t know how to use Python, and I’m just starting to figure out. For instance I’ve in the past on other Linux distros, been dealing with several pyhton installs, 2.7 and 3 and I’m not used to declaring a “path”. this is the errors i get using some extensions that cant’t be loaded or commands on bash (gdal) that doesnt work. thanks for helping me
Grass : 2024-05-21T10:00:23 CRITICAL Problem with GRASS installation: GRASS was not found or is not correctly installed
icetool (very important to me now):
Impossible de charger l’extension ‘ICEtool’ provoque une erreur lors de l’appel à sa méthode classFactory()
ModuleNotFoundError: No module named ‘pandas’
File “/usr/lib/python3.12/site-packages/qgis/utils.py”, line 426, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/ICEtool/init.py”, line 36, in classFactory
from .ICEtool import ICEtoolPlugin
File “/usr/lib/python3.12/site-packages/qgis/utils.py”, line 923, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/ICEtool/ICEtool.py”, line 37, in
from .ICEtool_provider import ICEtoolProvider
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/ICEtool/ICEtool_provider.py”, line 44, in
from .Scripts.Step4_ComputeTemperatureCSV import ComputeGroundTemperatureCSV
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/ICEtool/Scripts/Step4_ComputeTemperatureCSV.py”, line 32, in
import pandas as pd
ModuleNotFoundError: No module named ‘pandas’Version de Python : 3.12.3 (main, Apr 23 2024, 09:16:07) [GCC 13.2.1 20240417]
Version de QGIS : 3.36.2-Maidenhead Maidenhead, exportedChemin Python :
/usr/share/qgis/python
/usr/share/qgis/python/plugins
/usr/lib/python312.zip
/usr/lib/python3.12
/usr/lib/python3.12/lib-dynload
/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder
Vrtbuilder on qgis
Impossible de charger l’extension ‘vrtbuilderplugin’ provoque une erreur lors de l’appel à sa méthode initGui() (unable to load vrtbuilder plugin)
AttributeError: type object ‘QgsMapLayerProxyModel’ has no attribute ‘Filters’. Did you mean: ‘filters’?
File “/usr/lib/python3.12/site-packages/qgis/utils.py”, line 451, in startPlugin
plugins[packageName].initGui()
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/vrtbuilderplugin.py”, line 48, in initGui
from vrtbuilder.widgets import VRTBuilderWidget
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/widgets.py”, line 28, in
from .externals.qps.maptools import SpatialExtentMapTool
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/externals/qps/maptools.py”, line 54, in
from .utils import *
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/externals/qps/utils.py”, line 2420, in
class SelectMapLayersDialog(QgsDialog):
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/externals/qps/utils.py”, line 2421, in SelectMapLayersDialog
class LayerDescription(object):
File “/home/vincent/.local/share/QGIS/QGIS3/profiles/default/python/plugins/vrtbuilderplugin/vrtbuilder/externals/qps/utils.py”, line 2423, in LayerDescription
def init(self, info: str, filters: QgsMapLayerProxyModel.Filters, allowEmptyLayer=False):
AttributeError: type object ‘QgsMapLayerProxyModel’ has no attribute ‘Filters’. Did you mean: ‘filters’?Version de Python : 3.12.3 (main, Apr 23 2024, 09:16:07) [GCC 13.2.1 20240417]
Version de QGIS : 3.36.2-Maidenhead Maidenhead, exportedChemin Python : [python path]
/usr/lib/python3.12
