Problems after installing nvidia 575.64-5 drivers
a little confused
so I just installed the newest Nvidia drivers (575.64-5)
then I reboot my system and all of a sudden the os is running very choppy and my second screen isn’t being recognised, is there something I’ve done wrong?
i am running a nvidia 1650 laptop so im not sure if thats an issue or not
i am very new to arch and didnt realise this would happen
Hello and welcome,
please open the Terminal and type in or copy and paste garuda-inxi. Mark it and copy and paste here the output please. Use the </> sign or use tree ~ above and under it. So we can see which hardware you have to install the right Nvidia driver for your System.
We cant help without this info. Its also written in the Template that you deleted before to write the Message.
do i have to do it on my current system or can i get the inxi from a snapshot? as nothing is wanting to load
snapshot is fine, we need your specs :slight_smile:
But use garuda-inxi :smiley:
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/.snapshots/18/snapshot/boot/vmlinuz-linux-zen
root=UUID=9a4327a9-b2a5-4aa0-b8be-54eea460c6e5 quiet loglevel=3 ibt=off
rootflags=defaults,noatime,compress=zstd,subvol=@/.snapshots/18/snapshot
Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
serial: <superuser required> Chassis: type: 10 v: IdeaPad L340-15IRH Gaming
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
serial: <superuser required> part-nu: LENOVO_MT_81LK_BU_idea_FM_IdeaPad
L340-15IRH Gaming uuid: <superuser required> UEFI: LENOVO v: BGCN34WW
date: 05/21/2021
ID-1: BAT0 charge: 37.5 Wh (100.0%) condition: 37.5/45.0 Wh (83.4%)
volts: 12.7 min: 11.5 model: Celxpert L18C3PF1 type: Li-poly
serial: <filter> status: full cycles: 257
Info: model: Intel Core i5-9300HF bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0x104
Speed (MHz): avg: 2400 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 2400 6: 2400
7: 2400 8: 2400 bogomips: 38400
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: HDMI-A-1,eDP-1 empty: none
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 04ca:7070
class-ID: 0e02
gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,left model: 22W_LCD_TV serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 305 gamma: 1.2
size: 160x90mm (0.63x0.35") diag: 184mm (7.2") ratio: 16:9, 16:10 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 pos: right model: LG Display 0x05e5 built: 2018 res:
modes: 1920x1080
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 575.64 device-ID: 10de:1f91
surfaces: N/A
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: Trust Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 145f:02bc class-ID: 0300
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 07:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 0cf3:e500
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 387.53 GiB used: 54.87 GiB (14.2%)
model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: AL2QFXV7 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Hitachi model: HCC545016B9A300
size: 149.05 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0209 scheme: MBR
ID-1: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
ID-2: /home raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
used: 54.87 GiB (23.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /var/log raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 64.0 C mobo: N/A
Memory: total: 8 GiB available: 7.67 GiB used: 2.7 GiB (35.2%)
Processes: 327 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.97 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1778 libs: 525 tools: octopi,paru Compilers:
clang: 20.1.6 gcc: 15.1.1 Shell: garuda-inxi default: fish v: 4.0.2
Garuda (2.7.3-1):
System install date:     2025-06-28
Last full system update: 2025-06-29
Failed units:            systemd-remount-fs.service
thx for the garuda-inxi
For your system you need the open-dkms drivers.
Open the Terminal and copy and paste this commands for installing it.
sudo pacman -Rdd garuda-nvidia-config nvidia-dkms nvidia-settings nvidia-utils opencl-nvidia libxnvctrl lib32-nvidia-utils lib32-opencl-nvidia gwe python-py3nvml
no reboot and install
sudo pacman -S nvidia-open-dkms egl-wayland lib32-nvidia-utils lib32-opencl-nvidia nvidia-settings opencl-nvidia nvidia-utils
if its askinf for dependencies say yes (y Y)
hope it will solve your issue. If any problems please copy and paste the outputs like you did before with the garuda - inxi .
