Problem with UI scaling for apps in LxQT
Since I switched to LxQT desktop environment from KDE, I’ve noticed that some apps’ scaling UI doesn’t sync with my system-wide scaling (e.g., Skype with screenshot I’ve attached) and the app text and UI appeared really small
I hope somebody can provide me with some hints or solutions.
  Kernel: 6.5.11-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
    root=UUID=bb7cff58-98bd-45f2-aa8f-3d0233c379d2 rw rootflags=subvol=@
    verbose rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
  Desktop: LXQt v: 1.4.0 tk: Qt v: 5.15.11 info: cairo-dock, lxqt-panel
    wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: Latitude E6530 v: 01
  Mobo: Dell model: 024YM1 v: A01 serial: <superuser required> UEFI: Dell
    v: A17 date: 08/19/2015
  Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2535 high: 2890 min/max: 1200/3100 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 2698 2: 2282 3: 2271
    4: 2890 bogomips: 19933
  Device-1: NVIDIA GF108GLM [NVS 5200M] vendor: Dell driver: nvidia v: 390.157
    alternate: nvidiafb,nouveau,nvidia_drm non-free: series: 390.xx+
    status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
    gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0dfc
  Device-2: Microdia Laptop_Integrated_Webcam_E4HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.5:3
    chip-ID: 0c45:6449 class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
  Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
    s-diag: 391mm (15.39")
  Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 142
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
    16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
  Device-2: NVIDIA GF108 High Definition Audio vendor: Dell
    bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  API: ALSA v: k6.5.11-x64v2-xanmod1-1 status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.84 status: active with: 1: wireplumber
    status: off 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
    tools: pw-cat,pw-cli,wpctl
  Server-2: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl
  Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
    v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 8086:422b
  IF: wlp11s0 state: up mac: <filter>
  Local Storage: total: 585 GiB used: 80.52 GiB (13.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: OSC model: SSD 128GB size: 119.24 GiB
    serial: <filter> fw-rev: 7A scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS725050A7E630
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A3C0 scheme: GPT
  ID-1: / raw-size: 60.51 GiB size: 60.51 GiB (100.00%)
    used: 52.61 GiB (87.0%) fs: btrfs dev: /dev/sdb6 maj-min: 8:22
  ID-2: /boot/efi raw-size: 613 MiB size: 611.7 MiB (99.80%)
    used: 52 MiB (8.5%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 60.51 GiB size: 60.51 GiB (100.00%)
  ID-4: /var/log raw-size: 60.51 GiB size: 60.51 GiB (100.00%)
  ID-5: /var/tmp raw-size: 60.51 GiB size: 60.51 GiB (100.00%)
    zswap: no
  ID-1: swap-1 type: zram size: 7.7 GiB used: 1.02 GiB (13.2%) priority: 100
  System Temperatures: cpu: 71.0 C mobo: 46.0 C sodimm: SODIMM C gpu: nvidia
    temp: 66 C
  Fan Speeds (rpm): cpu: 3207
  Processes: 292 Uptime: 2h 7m wakeups: 0 Memory: total: 8 GiB
  available: 7.7 GiB used: 4.63 GiB (60.1%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1592 libs: 408 tools: octopi,pamac,paru,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: qterminal inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-14
  Last full system update: 2023-11-14 ↻
  Failed units:            systemd-remount-fs.service systemd-sysctl.service
 ╭─tcong97@cong in ~ took 8s
 ╰─λ sudo garuda-inxi
[sudo] password for tcong97:
    wm: kwin_x11 dm: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: Latitude E6530 v: 01 serial: <filter>
    Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 024YM1 v: A01 serial: <filter> UEFI: Dell v: A17
    date: 08/19/2015
  Info: model: Intel Core i5-3210M socket: rPGA988B bits: 64 type: MT MCP
    arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
    family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Speed (MHz): avg: 2344 high: 2986 min/max: 1200/3100 base/boost: 2500/2500
    scaling: driver: intel_cpufreq governor: performance volts: 0.0 V
    ext-clock: 100 MHz cores: 1: 2890 2: 2307 3: 2986 4: 1196 bogomips: 19933
  Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
  Server-1: PipeWire v: 0.3.84 status: n/a (root, process) with:
    1: wireplumber status: off 2: pipewire-alsa type: plugin 3: pw-jack
    type: plugin tools: pw-cat,pw-cli,wpctl
  Server-2: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-jack type: module tools: pacat,pactl
  Local Storage: total: 585 GiB used: 80.53 GiB (13.8%)
    block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 7A temp: 45 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 45d 5h cycles: 1828
    read: 498 MiB written: 242.1 MiB
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B sata: 3.0
    speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: A3C0
    temp: 46 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 72d 13h cycles: 1035 Old-Age:
    g-sense error rate: 590 Pre-Fail: end-to-end: 99 threshold: 97
    reallocated sector: 100 threshold: 5
    used: 52.62 GiB (87.0%) fs: btrfs block-size: 4096 B dev: /dev/sdb6
    maj-min: 8:22
    used: 52 MiB (8.5%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    maj-min: 8:22
    maj-min: 8:22
    maj-min: 8:22
    zswap: no
    temp: 64 C
  Fan Speeds (rpm): cpu: 3215
  Processes: 294 Uptime: 2h 7m wakeups: 0 Memory: total: 8 GiB
  available: 7.7 GiB used: 4.58 GiB (59.5%) Init: systemd v: 254
  pm: flatpak pkgs: 0 Shell: garuda-inxi (sudo) default: Bash v: 5.2.15
Garuda (2.6.19-2):
  Windows dual boot:       Yes
The simplest solution I can imagine is looking into the app’s settings and see if it has settings to increase font size or increase zoom. Also just to be sure have you restarted your system after changing screen scale?
I have looked into the apps, but not every app has an option to increase font size or zoom. I got those apps scaled perfectly to screen resolution in Windows 11
I am not on lxqt so I can’t say what might be happening with you. Can you describe how you set up global scaling? All the params you have changed? Maybe someone who uses lxqt will be able to point out any missteps in your config.
Meanwhile have a look at this.
Maintainer’s comments,
