Problem with my ssh session
HI,
I’M from linux mint and pop OS, and usualy to open my ssh session without having to add everytimes my passphrase, I always use a script in bashrc, so when I start a new session I just have to enter one my pass, but with garuda, when I open the session with konsole, I don’t receive the passphrase asking, do you know why? Maybe I have to do something else with garuda?
thanks
here the script:
if [ ! -S ~/.ssh/ssh_auth_sock ]; then
  eval `ssh-agent`
  ln -sf "$SSH_AUTH_SOCK" ~/.ssh/ssh_auth_sock
fi
export SSH_AUTH_SOCK=~/.ssh/ssh_auth_sock
ssh-add -l > /dev/null || ssh-add
root=UUID=73c23039-fcbf-4985-9c10-a4426ad13bb9 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Desktop System: Micro-Star product: MS-7B79 v: 3.0
Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.G0
date: 07/27/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1731 high: 3198 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3198 2: 1422
3: 1550 4: 1418 5: 1550 6: 1550 7: 1550 8: 1550 9: 3188 10: 1550 11: 1421
12: 1550 13: 1550 14: 1550 15: 1550 16: 1550 bogomips: 95999
Device-1: NVIDIA GF108 [GeForce GT 630] vendor: ZOTAC driver: nouveau
v: kernel non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last:
release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx
process: 40/28nm built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DVI-I-1,DVI-I-2 bus-ID: 27:00.0
chip-ID: 10de:0f00 class-ID: 0300 temp: 31.0 C
compositor: kwin_wayland driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: 0
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.4-arch1.2 glx-v: 1.4
direct-render: yes renderer: NVC1 device-ID: 10de:0f00 memory: 1.94 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.4-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GF108 High Definition Audio vendor: ZOTAC
bus-ID: 27:00.1 chip-ID: 10de:0bea class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
IF: enp34s0 state: down mac: <filter>
speed: 2.5 GT/s lanes: 1 bus-ID: 23:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp35s0 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:2 chip-ID: 8087:0a2a
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 698.65 GiB used: 216.51 GiB (31.0%)
fw-rev: 2B2QEXM7 temp: 28.9 C scheme: GPT
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
scheme: MBR
used: 9.95 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.54 GiB used: 31.2 MiB (0.2%)
System Temperatures: cpu: 28.1 C mobo: N/A gpu: nouveau temp: 31.0 C
Processes: 371 Uptime: 5h 1m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 4.64 GiB (29.8%) Init: systemd v: 255
pm: pacman pkgs: 1229 libs: 356 tools: octopi,paru,yay Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2024-02-01
Last full system update: 2024-02-01 ↻
Failed units:            user@959.service
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
here we go, sorry
Most likely not the root cause of your problem, but that symbol means that a reboot is pending after an update.
After that, you should probably investigate this
Additionally, rather than bashrc, I think you should use config.fish, because fish is the shell we use here by default.
I can’t help you much here, but give a look at this hint and, if necessary, the linked Arch wiki article.
What you are setting up is ssh agent and making it share a single session so that other terminals can use it as well. The only problem is you are setting it up for bash and garuda by default uses fish.
Go to,
~/.config/fish/config.fish
Put this at the end of file
if ! pgrep -u "$USER" ssh-agent > /dev/null;
    ssh-agent -c -t 1h > "$XDG_RUNTIME_DIR/ssh-agent.env"
end
if [ ! -f "$SSH_AUTH_SOCK" ];
    source "$XDG_RUNTIME_DIR/ssh-agent.env" >/dev/null
end
Save it exit it and open a new terminal.
Please note the -t 1h ensures that ssh agent only holds identities for a max time of 1h i.e. you would be asked to enter password again after an hour has passed. I do this for better security you can remove this flag if you want.
In new terminal type
ssh-add
This will prompt you to enter password for the ssh id you have created and add it to ssh-agent. Once done ssh session’s won’t request passwords unless the ssh-agent expires (due to -t flag) or you reboot.
You can
ssh-add -l
To see the identites ssh-agent currently has.
To read more,
https://wiki.archlinux.org/title/SSH_keys#SSH_agents
thank you very much, but ssh-add does not work, my script was about .ssh with my id_ed25519 key, but I guess I need to copy that to .config/fish ?
ssh-add
Could not open a connection to your authentication agent.
I added in config.fish
## Run fastfetch if session is interactive
if status --is-interactive && type -q fastfetch
fastfetch --load-config dr460nized
end
end
end
do you know what it could be?
Did you open a new terminal after adding that to config.fish? Because it says ssh-agent is not available.
It’s your system. Help yourself.
Either of
systemctl status user@959.service
Or
journalctl --grep user@959.service
Would show you what’s going on.
yes, but seems to work now after reboot
OpenSSH includes a user service that takes care of this for you. You just need to set the SSH_AUTH_SOCK="$XDG_RUNTIME_DIR/ssh-agent.socket" environment variable somewhere (in ~/.profile is fine) and enable the service.
systemctl --user enable --now ssh-agent.service
https://wiki.archlinux.org/title/SSH_keys#Start_ssh-agent_with_systemd_user
