Well , I installed garuda a few weeks ago , and everything is perfect , it is a very good distro , but today I noticed that when I connect my SD card to my notebook the card does not show up in the devices i run lspci -k in the terminal and this shows
08:00.0 Unassigned class [ff00]: Alcor Micro AU6625 PCI-E Flash card reader controller (rev ff)
Kernel driver in use: alcor_pci
Kernel modules: alcor_pci
Some ideas?
EDIT: the card reader is an integrated one
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=8834b33c-9d4b-4f14-9aa3-05d48960d0a6 rw rootflags=subvol=@
resume=UUID=283fe6c7-0ea2-47ec-82bd-3d13b377ac53 loglevel=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk1xxx
Mobo: HP model: 8742 v: 02.41 serial: <superuser required> UEFI: Insyde
v: F.31 date: 09/03/2021
ID-1: BAT1 charge: 42.7 Wh (100.0%) condition: 42.7/52.5 Wh (81.3%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4002 high: 4300 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 4292 2: 3586 3: 3797
4: 4285 5: 3163 6: 4300 7: 4300 8: 4295 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: Hewlett-Packard driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
lanes: 16 ports: active: none empty: DP-2,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b627 class-ID: 0e02
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP-1-1 model: BOE Display 0x094a built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0
bus-ID: 1-14:3 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 253.31 GiB used: 53.07 GiB (21.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SB16G size: 14.84 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNV256G KIOXIA size: 238.47 GiB block-size: physical: 512 B
rev: HP00AE00 temp: 23.9 C scheme: MBR
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 22.68 GiB (18.9%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 102.34 GiB size: 102.34 GiB (100.00%)
used: 30.39 GiB (29.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
used: 22.68 GiB (18.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 120 GiB size: 120 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.43 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 49.0 C pch: 53.0 C mobo: 10.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 331 Uptime: 11h 52m wakeups: 1 Memory: 15.43 GiB
used: 6.64 GiB (43.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2148 lib: 564 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-25
Last full system update: 2022-03-27 ↻
Failed units: auditd.service nmb.service shadow.service
SGS
27 March 2022 01:56
4
And
First, reboot.
It work before?
If yes, check pacman log what changed, I think older snapshot dos not exist.
No , I understand that it never worked , it was the first time I inserted the card sorry for that My mistake was specifying that it is the first time I installed the distro on my notebook , I had it on my desktop PC the speed of the system was perfect so I decided to install it in my notebook with windows 10 since it still had the usb, and I put some important files from the notebook on the sd card and i notice this
SGS
27 March 2022 02:07
6
Check arch wiki with your laptop name
HP Pavilion Gaming Laptop 15-dk1xxx, HP model: 8742 etc for card reader driver.
This is the driver Alcor Micro AU6625 PCI-E Flash card reader controller
How i installed? i just install the nvidia drivers with the classic Pacman -S
system
Closed
29 March 2022 02:19
10
