Problem with Lutris dark theme
Hi
After update 2 days ago my lutris app is displayed in white theme… and I did not change any settings except updating with garuda-update.
It looks like that:
The dark theme switch in Lutris was off when it happened and I think it was using dark theme anyways… non the less the switch is not working anyway.
Also some apps like lutris and firefox have wrong close/minimize/hide icons, and some apps like dolphin, gwenview have good icons.
Can some one help me to fix this? I don’t care much for icons… but without dark theme my eyes are in pain :cry:
Kernel: 6.11.5-arch1-1-znver4 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver4
root=UUID=c18d949d-69a4-4160-97bc-bf86a790a7fa rw rootflags=subvol=@
usb-storage.quirks=152d:0578:u quiet
resume=UUID=835dc304-471d-4f63-9dd4-a52860dc3408 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Desktop Mobo: ASRock model: B650E Steel Legend WiFi
Megatrends LLC. v: 2.08 date: 03/01/2024
Info: model: AMD Ryzen 5 7500F bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3632 min/max: 400/5074 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3632 2: 3632 3: 3632
4: 3632 5: 3632 6: 3632 7: 3632 8: 3632 9: 3632 10: 3632 11: 3632 12: 3632
bogomips: 88662
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti 16GB] vendor: Micro-Star MSI
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 10de:2805 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia display-ID: 0
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
memory: 15.62 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Ti driver: nvidia v: 560.35.03 device-ID: 10de:2805
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM 18.1.8)
Device-1: NVIDIA AD106M High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Thesycon System & Consulting GmbH SABAJ DA2 v1.2
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-2:2 chip-ID: 152a:85df class-ID: fe01
API: ALSA v: k6.11.5-arch1-1-znver4 status: kernel-api tools: N/A
Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 14c3:0608
IF: wlp7s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0e8d:0608
Local Storage: total: 3.68 TiB used: 2.02 TiB (54.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 11296 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 1.82 TiB block-size: physical: 512 B
fw-rev: VC2S038D temp: 34.9 C scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 892.65 GiB (47.7%)
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 892.65 GiB (47.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.96 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.16 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.5 C mobo: 37.5 C
Memory: total: 32 GiB note: est. available: 30.96 GiB used: 4.14 GiB (13.4%)
Processes: 356 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,
Packages: 2215 pm: pacman pkgs: 2205 libs: 502 tools: paru pm: flatpak
pkgs: 10 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2023-12-08
Last full system update: 2024-10-23
Ask Lutris :slight_smile:
Try reapplyng the global theme.
From system settings or simply
lookandfeeltool --resetLayout --apply Dr460nized
Try this,
Go here. Color an themes - application style - config gnome/gtk an check your theme here sometimes it likes to reset from time to time.
Then,
Rarely but some times you might have to go into “Get New” and update the one your using cause gtk is weird.
unfortunately it did not helped.
I also deleted conifg file of lutris and no effect.
on startup lutris produces only this error:
(lutris:5559): Gtk-WARNING **: 18:47:50.613: Could not load a pixbuf from icon theme.
This may indicate that pixbuf loaders or the mime database could not be found.
also I found Lutris ignores dark GTK theme: arch, kde, wayland · Issue #5520 · lutris/lutris · GitHub similar problem, but I am not sure how to apply proposition from last comment.
Also few apps have the same problem with close/minimize icons but they properly display dark theme.
Thank You Savior :slight_smile:
The option in settings was empty :slight_smile:
I set adw-gtk-dark and is working now :slight_smile:
It must have cleared for whatever reason during update…
Its a weird setting it happens from time to time i cant say if its kde or gnome at fault but at least its fixable.
There is a new sweet theme in the get new at the bottom of that window if you want lutris to mach they system theme more.
Thx for suggestion… sweet also repaired icons in firefox and few other GTK apps
Zrzut ekranu_20241023_190247
I might have found solution myself… but when I typed in settings search bar word “gtk” I was redirected to Application styles but I failed to see that option in top right corner :slight_smile:
