Synchronizing package databases...
garuda is up to date
core is up to date
extra is up to date
chaotic-aur 639,0 KiB 387 KiB/s 00:02 [--------------------------------------] 100%
AUR Explicit (2): linux-xanmod-lts-linux-headers-bin-x64v3-6.12.41-1, linux-xanmod-lts-linux-bin-x64v3-6.12.41-1
:: PKGBUILD up to date, skipping download: linux-xanmod-lts-linux-bin-x64v3
==> Making package: linux-xanmod-lts-linux-bin-x64v3 6.12.41-1 (mer. 06 août 2025 19:06:06)
==> Retrieving sources...
-> Found linux-image-6.12.41-x64v3-xanmod1_6.12.41-x64v3-xanmod1-0~20250801.g8269fa8_amd64.deb
-> Found linux-headers-6.12.41-x64v3-xanmod1_6.12.41-x64v3-xanmod1-0~20250801.g8269fa8_amd64.deb
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with sha256sums...
linux-image-6.12.41-x64v3-xanmod1_6.12.41-x64v3-xanmod1-0~20250801.g8269fa8_amd64.deb ... Passed
linux-headers-6.12.41-x64v3-xanmod1_6.12.41-x64v3-xanmod1-0~20250801.g8269fa8_amd64.deb ... Passed
:: (1/1) Parsing SRCINFO: linux-xanmod-lts-linux-bin-x64v3
gpg: error reading key: No public key
pub rsa4096 2011-09-23 [SC]
647F28654894E3BD457199BE38DBBDC86092693E
uid [ unknown] Greg Kroah-Hartman <gregkh@linuxfoundation.org>
uid [ unknown] Greg Kroah-Hartman <gregkh@kernel.org>
uid [ unknown] Greg Kroah-Hartman (Linux kernel stable release signing key) <greg@kroah.com>
sub rsa4096 2011-09-23 [E]
:: PGP keys need importing:
-> ABAF11C65A2970B130ABE3C479BE3E4300411886, required by: linux-xanmod-lts-linux-bin-x64v3
:: Import? [Y/n]
:: Importing keys with gpg...
gpg: keyserver receive failed: No data
-> problem importing keys
Kernel: 6.16.0-xanmod1-1-edge-x64v3 arch: x86_64 bits: 64 compiler: gcc
v: 15.1.1 clocksource: tsc avail: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge-x64v3
root=UUID=e0869f39-b7a0-4c19-8e3f-ce38d8d65169 rw rootflags=subvol=@
loglevel=3 sysrq_always_enabled=1 systemd.unified_cgroup_hierarchy=1
fwlps=0 btusb.enable_autosuspend=0 usbcore.autosuspend=-1 ibt=off
Desktop: GNOME v: 48.4 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: X540LA v: 1.0
Mobo: ASUSTeK model: X540LA v: 1.0 serial: <superuser required>
part-nu: ASUS-NotebookSKU uuid: <superuser required>
UEFI: American Megatrends v: X540LA.304 date: 04/17/2019
ID-1: BAT0 charge: 21.1 Wh (98.1%) condition: 21.5/33.2 Wh (64.9%)
volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 954
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1996 min/max: 500/1900 scaling: driver: intel_cpufreq
governor: performance cores: 1: 1996 2: 1996 3: 1996 4: 1996 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: DP-1
off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 13d3:5a11
class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting
Monitor-1: DP-1 model: Samsung SyncMaster serial: <filter> built: 2009
res: 1600x900 dpi: 92 gamma: 1.2 size: 443x249mm (17.44x9.8")
diag: 508mm (20") ratio: 16:9 modes: max: 1600x900 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) device-ID: 8086:1616 memory: 7.47 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 5500 (BDW GT2) driver: mesa intel v: 25.1.7-arch1.1
device-ID: 8086:1616 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: gputop,
intel_gpu_top, lsgpu x11: xdpyinfo, xprop, xrandr
Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
API: ALSA v: k6.16.0-xanmod1-1-edge-x64v3 status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 02:00.2 chip-ID: 10ec:8136 class-ID: 0200
IF: enp2s0f2 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On
driver: rtl8723be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:16
Report: btmgmt ID: hci0 rfk-id: 13 state: up address: N/A
Device-2: Realtek Bluetooth Radio driver: N/A type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:b721
class-ID: e000 serial: <filter>
Local Storage: total: 704.24 GiB used: 63.26 GiB (9.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253256GB
tech: SSD serial: <filter> fw-rev: 227N scheme: GPT
model: WD5000LPCX-80VHAT1 size: 465.76 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-1: / raw-size: 15.18 GiB size: 15.18 GiB (100.00%) used: 9.45 GiB (62.3%)
ID-2: /home raw-size: 19.53 GiB size: 19.53 GiB (100.00%)
used: 8.41 GiB (43.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-3: /var/log raw-size: 15.18 GiB size: 15.18 GiB (100.00%)
used: 9.45 GiB (62.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/tmp raw-size: 15.18 GiB size: 15.18 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 7.65 GiB used: 3.11 GiB (40.7%)
System Temperatures: cpu: 68.0 C pch: 62.5 C mobo: N/A
Memory: total: 8 GiB available: 7.65 GiB used: 5.28 GiB (69.0%)
Processes: 302 Power: uptime: 1d 7h 54m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 5 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.03 GiB services: gsd-power,
Packages: 1177 pm: pacman pkgs: 1128 libs: 273
tools: gnome-software,paru,yay pm: flatpak pkgs: 49 Compilers: gcc: 15.1.1
Shell: Bash v: 5.3.3 default: fish v: 4.0.2 running-in: blackbox
inxi: 3.3.38
Garuda (2.7.4-1):
System install date: 2024-09-21
Last full system update: 2025-08-06 ↻
Failed units: pkgfile-update.service
You have a pending reboot, please do that first and try again
filo
3
Try with a different keyserver, like here:
Or e.g. pgp.mit.edu
Question about linux-xanmod-edge-x64v3 , does it have v3 features enabled when installed from the chaotic-aur ?
system
Closed
7
