Problem with external monitor brightness
hi, before i start i want to say that i did search this up an found nothing about the exact same problem i have
the problem is when my laptop goes to sleep, when i come back to it after a few hours and open it back the brightness of my external screen gets reduced to 30%. the problem is that this isnt done to garuda’s brightness settings but to the screen’s internal settings . Garuda shows that both the laptop and external screen are at 100% but the external one got the internal settings reduced to 30%
does anyone know how to fix this ?
and this is my system:
root=UUID=38b8c0fd-ad69-49a0-886d-580605beb2ef rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DA_X512DA
Mobo: ASUSTeK model: X512DA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: X512DA.318
date: 09/28/2022
ID-1: BAT0 charge: 23.5 Wh (98.3%) condition: 23.9/37.1 Wh (64.4%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 215
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2769 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2769 2: 2769 3: 2769
4: 2769 5: 2769 6: 2769 7: 2769 8: 2769 bogomips: 33535
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 65.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.2:5
chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: HDMI-A-1 pos: right model: Idek Iiyama PL2730H serial: <filter>
built: 2018 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x07f1 built: 2018
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven ACO DRM 3.63 6.15.3-zen1-1-zen) device-ID: 1002:15d8
API: Vulkan v: 1.4.313 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 25.1.4-arch1.1
device-ID: 1002:15d8 surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.15.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: IMC Networks driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.1:4 chip-ID: 13d3:3491
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: N/A
Local Storage: total: 1.14 TiB used: 325.28 GiB (27.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ3 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK1A.2 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD Blue SA510
2.5 1000GB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 6100 scheme: GPT
ID-1: / raw-size: 150 GiB size: 150 GiB (100.00%) used: 21.02 GiB (14.0%)
used: 31.9 MiB (12.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 150 GiB size: 150 GiB (100.00%)
used: 21.02 GiB (14.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 150 GiB size: 150 GiB (100.00%)
ID-5: /var/tmp raw-size: 150 GiB size: 150 GiB (100.00%)
ID-1: swap-1 type: zram size: 17.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 64.5 C mobo: N/A gpu: amdgpu temp: 64.0 C
Fan Speeds (rpm): cpu: 2700
Memory: total: 20 GiB note: est. available: 17.5 GiB used: 10.08 GiB (57.6%)
Processes: 360 Power: uptime: 4h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.98 GiB services: org_kde_powerdevil,
Packages: 1422 pm: pacman pkgs: 1415 libs: 383 tools: octopi,paru,yay
pm: flatpak pkgs: 7 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish
System install date:     2025-06-25
Last full system update: 2025-06-27
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
hi,
sounds for me as a technical stuff Hardware related maybe you can check if the Monitor is in ECO mode or Energy Safe Mode after certain time. Did you try unplug the Power cord from the Monitor and DP Cable for few Minutes . Plug Monitor Power back and DP Cable to see if its come on back on with the right Brightness. Which BOE monitor is it? Can you try the HDMI Port if it has one to check the same behavior?
its not ive checked with miltiple monitors with tons of different settings and it seems to be an issue related to garuda
my bad to hear that issue persist and its not hardware related. i had it one but it was my TV did go in energy mode and hangs until i did this Steps.
somehow it fixed itself ? i mean i did some updates but it didnt do anything imeidatly after this or after restarting . i just used the scrol wheel of the mouse on the icon to increase the brightness when it was already at 100% and somehow the brightess increased back to the internal settings … when i tried this before it didnt work…idk whats happening i guess a few updates and luck works but still
