Hello guys.
So I have docker installed and running on my pc, but I have this error where it tells me "your kernel does not support cgroup rt runtime".
I need to use codeclimate, and every time I try to use it, this message shows up:
"docker: Error response from daemon: cgroups: cgroup mountpoint does not exist: unknown"
Please, I need help.
Garuda uses cgroups v2 by default
While docker has just added support for it recently
I think two days ago
Ok, so what do I need to do in order to use it?
Docker 20.10 adds cgroups-v2 support which should make docker work without any workarounds
This thread has it all I guess
Install docker-git from pacman, works with cgroups2
Tried that, but got this error:
fish: /usr/share/fish/completions/docker.fish exists in filesystem
How do I fix this?
Where do I use that line?
sudo pacman --overwrite "*" -S docker-git
As paman option
SGS
12 December 2020 22:49
11
sudo pacman -Syu docker-git --overwrite "*"
add , I mean at the end.
Hope it help.
Same error. I'll have to find another way because docker-git is not in the repository.
Thank you very much.
