Hi, I have problem with the latest bauh. It only shows what I have installed, but thats program that I don’t have. When I tried to refresh all disappear and the window is empty. I tried the bauh-staging but have the same problem. Are there any fixies for this or should I remove Bauh?
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=314ff52d-46d3-4f33-846c-f89b5db3a9dd rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: Z77 Extreme4 serial: <superuser required>
UEFI: American Megatrends v: P2.90 date: 07/11/2013
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3673 high: 3900 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3900 3: 3900
4: 3900 5: 3900 6: 2086 7: 3900 8: 3900 bogomips: 54405
Device-1: Intel IvyBridge GT2 [HD Graphics 4000] vendor: ASRock driver: i915
active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0162 class-ID: 0300
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: HDMI-A-3 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: crocus wayland: drv: crocus x11:
drv: crocus inactive: gbm
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0162 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4000 (IVB GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:0162 surfaces: xcb,xlib,wayland device: 1 type: cpu
vendor: ASRock Z77 Extreme4 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster
Audigy Series] driver: snd_emu10k1 v: kernel bus-ID: 05:00.0
chip-ID: 1102:0004 class-ID: 0401
Device-3: Asahi Kasei Microsystems AK5370 I/F A/D Converter
driver: snd-usb-audio type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1
bus-ID: 1-1.6:3 chip-ID: 0556:0001 class-ID: 0102
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
Device-1: Broadcom NetLink BCM57781 Gigabit Ethernet PCIe
vendor: ASRock Z77 Extreme4 driver: tg3 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 14e4:16b1
Hardware-1: VIA VT6421 IDE/SATA Controller driver: sata_via v: 2.6
port: d000 bus-ID: 05:01.0 chip-ID: 1106:3249 rev: N/A class-ID: 0104
Local Storage: total: 5.19 TiB used: 920.84 GiB (17.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Maxtor model: 6L300S0 size: 279.48 GiB
block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s tech: N/A
serial: <filter> fw-rev: 1G10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 1TB
model: WD5000AAKS-00A7B0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 3B01
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: HD401LJ
size: 372.61 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 0-15 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD30EZRX-00SPEB0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 vendor: Western Digital
logical: 512 B speed: 1.5 Gb/s tech: N/A serial: <filter> fw-rev: 3B01
ID-1: / raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
used: 8.91 GiB (7.4%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.79%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 748.55 GiB size: 748.55 GiB (100.00%)
used: 5.18 GiB (0.7%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-4: /var/log raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
ID-5: /var/tmp raw-size: 120.12 GiB size: 120.12 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 62.5 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 336 Uptime: 10m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.05 GiB used: 3.82 GiB (12.3%) Init: systemd v: 254
pm: pacman pkgs: 1379 libs: 412 tools: octopi,pamac,paru,yay Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-10
Last full system update: 2023-10-17
